Hello there,
I am attempting to port the code for the Pulse Sensor Amped (PSA) from an UNO R3 (AVR) to the CPX (SAMD). I am attempting to use the Adafruit_ZeroTimer library but I don't know the usage. I tried using the code from the Pulse Room project since the processor architecture is the same, but I get compile errors on the Adafruit_ZeroTimer setCallback method.
I am using Arduino 1.8.5 and Adafruit_ZeroTimer 2.0.0 and the project code from Pulse Room. interrupt.ino has compiler errors. The same errors show up with both a Feather M0 and a CPX selected as the boards. This is very much out of my comfort zone but I am learning a lot about the microcontroller timing techniques.
Is there an API for Adafruit_ZeroTimer? I need a 2ms counter for a Pulse Sensor Amped project. I did try compiling the examples with the library and got no errors. I am attaching the verbose error log from Arduino IDE. Any help would be awesome!
Adafruit_ZeroTimer Usage for CPX
- jimmynewland
- error_log.txt
- (13.94 KiB) Downloaded 59 times
- jimmynewland
Re: Adafruit_ZeroTimer Usage for CPX
Well I at least got the code to compile. I noticed the Adafruit_ZeroTimer library had been updated and looked at the examples and saw the call to the constructor was now zero-args. So I got it to compile but I can't get data into the CPX from the A1 pin. I'll keep at it.
- ctymms
I had a similar compiler error when I first user the 2.0.0 version. The older version was working fine. What I did discover is that the zerotimer library with the Example Callback sketch did not compile properly with the new Itsybitsy M4 express. It shows many non declared tc variables errors. It only shows problem when selecting the ItsyBitsy M4 but complies OK with the Metro M4 and Feather M4.
