I'm hooking a 2-axis joystick to a CRICKET with Circuit Playground Express.
The MakeCode is pretty simple:
forever(function () {
crickit.servo1.setAngle(crickit.signal1.analogRead())
crickit.servo2.setAngle(crickit.signal2.analogRead())
So, the results are that it responds to the joystick pushed up, and to the right, but ignores to the left and down.
I'm using these joysticks: http://a.co/5DMA3WB
So, I'll gratefully accept advice to get it working, but I'd also welcome information to track values read from the joystick. I see the console drawer in advanced section of the tools menu, and I can produce a line like this: console.logValue("x", crickit.signal1.analogRead())
So, how do I read this console? If I connect to the Circuit Playground USB connection, using putty, I only have a valid serial device when the Circuit Playground is in programming mode. And I don't see any info on that serial device in that mode, using putty to connect to it.
How do I read that console?
using console to troubleshoot Circuit Playground Express, CR
- troublesturm
- troublesturm
Re: using console to troubleshoot Circuit Playground Express
Found it.
The console is available in the MakeCode app.
https://www.microsoft.com/en-us/p/makec ... verviewtab
It showed me that the joystick was returning values between 0 and 1024, and the servos expect values between 0 and 180 (as in degrees). So I needed to divide it by 5.688888888 (the result of 1027/180).
So, now my code looks like this:
crickit.servo1.setAngle(crickit.signal1.analogRead() / 5.688888)
crickit.servo2.setAngle(crickit.signal2.analogRead() / 5.688888)
console.logValue("x", crickit.signal1.analogRead() / 5.688888)
console.logValue("y", crickit.signal2.analogRead() / 5.688888)
