I can not get codemaker on Playground Classic
Play with it! Please tell us which board you're using.
iAMg33kster
Post by iAMg33kster »
I can't tell you how many forums I've read, or try this videos I have watched. But I just got a playground classic and hooked it up to ardunio and the thing works great! It runs the code. But now I want to put codemaker files on it. And my computer does not see it as a drive. Now I have tried different cables even Mac's and PC computers, 4 Different ones at that! I can't seem to get the Ardiuno code off the playground and put makecode on it. Oh and I have even clicked the reset button once and then done the 2 times bootload press and have 10 Seconds it goes right back into the code.
Is there someone I can call who can walk me thru how to fix this problem?
Thank you in advance.
millercommamatt
Re: I can not get codemaker on Playground Classic
Post by millercommamatt »
I think you can only use the makecode on the Playground Express.
The product page for the Playground Classic says:
This is the Classic version of Circuit Playground, which comes with an ATmega32u4. It's designed to be used with Arduino IDE and code.org CS Discoveries only. It even comes with Firmata already programmed in, so you can use it immediately with code.org Discoveries without any preparation or updates.
If you would like to use MakeCode or CircuitPython, check out Circuit Playground Express, which can be used with MakeCode, CircuitPython or Arduino.
adafruit_support_carter
What was said above is correct. Do you actually have a Circuit Playground Classic?
https://learn.adafruit.com/adafruit-cir ... vs-express
iAMg33kster
This totally makes sense I completely ordered the wrong one. I though both of them could do makecode. Is there any way to pay the difference and send the classic back?
Sorry, not really. Once you've opened and used something we can't return it.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
