CPX not working
Play with it! Please tell us which board you're using.
brandontclee
CPX not working
Post by brandontclee »
Hi Hi!
I purchased 12 Circuit Playground Expresses for my classroom a couple months ago We took them out this month to use. About half of them work fine, and the other half have the same issue.
- When plugged in, only the "on" light turns on
- when the reset button is pressed, nothing happens
- various power sources and cables have been tried
- They are not connected to the crickit
I have attached a picture that shows what they look like. All 7 are plugged into different power sources. Any suggestions would be much appreciated!
https://imgur.com/a/huWJ9K0
Clopez718
Re: CPX not working
Post by Clopez718 »
Same issue here with my own! What is going on? I see many with this same issue on the forums.
Edit: whoops didnt see this was the same user on the other post who was making own thread, i did the same
adafruit_support_carter
Re: CPX not working
Are you using the same computer / USB cable / USB port etc. from one the CPX's that does work? (to rule out cable / port / operating system issues).
When you plug in one of the problematic ones, does the computer do anything? Make a "new hardware attached" noise, or anything?
Try double pressing reset also.
Were they at some point?
brandontclee
Re: CPX not working
1) The computer does nothing. Also, in the image, some are plugged into macbooks and the others into chromebooks over 4 different usb ports
2) I've tried double pressing reset. No change. Can upload a video if needed.
3) Some were. Some weren't.
Re: CPX not working
Inlining image for reference:
Re: CPX not working
Sounds like there was previous use here. These are not freshly delivered boards, correct? Can you elaborate on what these boards have been used for up to this point?
brandontclee
Re: CPX not working
Pretty basic stuff. My students used them just as they were. Plugged into the computer for power and coded using makecode. We made basic LED patterns, tried using the sensors a bit, but nothing really crazy. We had two die within the first few days and I assumed those were bunk. But then they all started to drop and I became concerned.
We are now using CRICKITS with the ones that survived and those are holding up fine.
Re: CPX not working
Is it possible the power pads got shorted, or some other in correct wiring connection on the pads? Or were they just using the on board sensors?
brandontclee
Re: CPX not working
We haven't even started using the pads. Literally all we did was like, turn a light on when you clap and make a loud noise when it shakes.
Re: CPX not working
Can you check what version of MakeCode you were running. If possible, a screen shot of the info would help. You can find out by clicking the gear icon and then About...
Thanks.
brandontclee
Re: CPX not working
Adafruit Circuit Playground Express version: 1.2.12
Microsoft MakeCode version: 5.1.5
codal-circuit-playground runtime version: v1.5.6
brandontclee
Re: CPX not working
Screen Shot 2019-03-06 at 12.27.28 PM.png (40.38 KiB) Viewed 160 times
brandontclee
Re: CPX not working
Just want to bump this because the CPX are still broken
Re: CPX not working
Thanks for the info. This looks different than an ongoing issue we do know about the MakeCode and servo usage. They worked, and then didn't. It's possible the students are doing things and exactly what isn't being captured. We can replace them, but please keep an eye on how they are used, so if it happens again it can hopefully be correlated to something.
Send an email to [email protected] with a link to this thread and your order number and they can get you replacement CPXs (PID 3333).
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
