MAX31865
Play with it! Please tell us which board you're using.
isuprotein
MAX31865
Post by isuprotein »
I have two MAX31865 boards that I can’t seem to communicate with on my Pi3B+. I have connected them as indicated in https://learn.adafruit.com/adafruit-max ... duino-code. When I run “i2cdetect -y 1” I get
Screen Shot 2019-08-26 at 9.57.45 AM.png (146.96 KiB) Viewed 270 times
I have one of these with the everything soldered on and an RTD1000 connected.
The other I just have pinned to a breadboard.
I believe I have everything installed correctly but I cannot get the CIRCUITPY drive to show up. Any ideas?
Franklin97355
Re: MAX31865
Post by Franklin97355 »
You need the soldered connections for sure. Can you post a picture of the board connected to your Pi?
isuprotein
Re: MAX31865
I thought if there are no soldered connections across the jumper, it would be setup for 4-wire, is that not correct?
Pi picture below
Franklin97355
Re: MAX31865
I'm talking about the connections on the header end. You need to solder a header or jumpers to the board. Check this out. https://learn.adafruit.com/adafruit-max ... e#assembly
isuprotein
Re: MAX31865
I tried it with both boards, the one that is soldered and the one in the picture with the Pi. The soldered one does not give any address with "i2cdetect -y 1" either.
isuprotein
Re: MAX31865
I think the root problem of this is that I don't see a CIRCUITPY drive mounted when I connection the board. How do I troubleshot that issue?
Franklin97355
Re: MAX31865
Which Circuit Playground are you connecting to and can we see those connections?
isuprotein
Re: MAX31865
I am only connecting the MAX31865 directly to the Pi. I have two MAX31865, one soldered for a three wire sensor and one with only the header pins soldered on. I have tried both of these on two different Pis and can't get either one to show a CIRCUITPY drive.
Franklin97355
Re: MAX31865
You won't get a CIRCUITPY drive on the Raspberry Pi as that is a drive from the Circuit Playground board which you are not using.
isuprotein
Re: MAX31865
That makes sense, I was following the CircuityPython instructions. However, I don't see anything when I run 'i2cdetect -y 1'. How would I troubleshoot that? In the instructions (Installing CircuitPython on Raspberry Pi), I am put to the point where i2c and SPI are enabled and then tested.
Franklin97355
Re: MAX31865
When you run that code what do you get?
isuprotein
Re: MAX31865
Screen Shot 2019-09-14 at 6.48.11 AM.png (373.72 KiB) Viewed 149 times
isuprotein
Re: MAX31865
How can I initiate to send these back or send to you for testing?
Franklin97355
Re: MAX31865
Send a note containing a link to this page and your order number to [email protected]. They will get you a refund. You can keep the ones you have but you shouldn't buy another from us as they probably won't work any better as ours are tested before shipping.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
