Pin Input problem
Play with it! Please tell us which board you're using.
Sandy_Crack
Pin Input problem
Post by Sandy_Crack »
I'm have issues with getting my CPE to react properly to an external limit switch connected up to a pin.
It works as expected if I short the terminals on the CPE with a short wire, but when I use a limit switch attached with a few feet of hook up wire , the input is always activated.
I've checked the switch and the wiring and all that checks out.
I suspect the input pin is set up for capacitance.
How do I change the input type or its tolerance .
In one of John Parks videos on touch switches he indicates you can change the tolerance by doesn't give details how.
dastels
Re: Pin Input problem
Post by dastels »
Seeing your code would help. Please use the code tags around it for readability.
Sandy_Crack
Thanks for your offer of help.
As you will see, the code is quite simple & I don't suspect the code ( as presented ) is the issue.
Just to re-iterate
- The input behaves as expected when touched - goes low.
- When Alligator clip jumper is attached to the input ( with the other end un-terminated ) the input goes low - this makes me suspect capacitance of the wiring is the issue.
- When I take this wire to GND as the input is already triggered , nothing happens, when I take the wire to 3.3v the input reacts as ( I ) expected.
So does anyone know a way of changing the tolerance/sensitivity of the touch inputs
Thanks In Advance
input.pinA4.onEvent(ButtonEvent.Up, function () {
    light.setAll(0xff0000)
input.pinA4.onEvent(ButtonEvent.Down, function () {
    light.setAll(0x00ff00)
Code v2.tiff
Code v2.tiff (68.17 KiB) Viewed 69 times
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
