CircuitPython NeoPixel Color Picker Example
Play with it! Please tell us which board you're using.
usmarine0622
Post by usmarine0622 »
When I run the code in the CircuitPython NeoPixel Color Picker Example I keep getting the error shown below. I followed the instrctions and have all the libs but I keep getting that error. I also posed the code I'm using below. I'm using the Circuit Playground Bluefruit - ALPHA - Bluetooth Low Energy
File "code.py", line 11, in <module>
TypeError: function missing required positional argument #3
* Code I'm using*
# CircuitPython NeoPixel Color Picker Example
import board
import neopixel
from adafruit_ble.uart_server import UARTServer
from adafruit_bluefruit_connect.packet import Packet
from adafruit_bluefruit_connect.color_packet import ColorPacket
uart_server = UARTServer()
pixels = neopixel.NeoPixel(board.NEOPIXEL, 10, brightness=0.1)
while True:
# Advertise when not connected.
uart_server.start_advertising()
while not uart_server.connected:
pass
while uart_server.connected:
packet = Packet.from_stream(uart_server)
if isinstance(packet, ColorPacket):
print(packet.color)
pixels.fill(packet.color)
V2man
Re: CircuitPython NeoPixel Color Picker Example
Post by V2man »
V2man
Post by V2man »
Your code will be more readable if you use the code tab above and insert your code in between. This is what the original ble_color_picker.py looks like:
import board
import neopixel
while True:
        pass
            print(packet.color)
usmarine0622
V2man wrote:See this post viewtopic.php?f=58&t=157616
I followed everything In that post and still have the error.
V2man
Post by V2man »
You got the adafruit_ble folder to copy to CIRCUITPY/lib from https://github.com/adafruit/Adafruit_Ci ... .1-alpha.2 ? Not from the bundle CircuitPython 5.0.0-alpha.4.
What are the contents of your CIRCUITPY/boot_out.txt?
Are you using MU editor with mode set to Adafruit Circuit Python?
usmarine0622
V2man wrote:You got the adafruit_ble folder to copy to CIRCUITPY/lib from https://github.com/adafruit/Adafruit_Ci ... .1-alpha.2 ? Not from the bundle CircuitPython 5.0.0-alpha.4.
Yes
Yes
Adafruit CircuitPython 5.0.0-alpha.4 on 2019-09-15; Adafruit Circuit Playground Bluefruit with nRF52840
V2man
Post by V2man »
What does Check in MU say?
You are sure you are using the code.py file from the CIRCUITPY drive in MU?
Do want to try the latest experimental uf2s?
This is what I am running on my CPB.
Download adafruit-circuitpython-circuitplayground_bluefruit-en_US-20191024-9d7b984.uf2 from https://adafruit-circuit-python.s3.amaz ... uit/en_US/
Press reset twice on the CPB to get CPLAYBTBOOT drive.
Copy the uf2 you just downloaded to the CPLAYBTBOOT drive.
Now what happens?
usmarine0622
I have it working now, I removed each lib and added them back one at a time while watching the output. It looks like the neopixel lib file was causing the problem, I replaced it with a fresh download and it's working. I appreciate your time in looking into this with me, this is my first time using one of these.
V2man
Post by V2man »
Great. Success that's what I like to hear!
With Alpha product you have to remember the libraries are changing everyday.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
