Converting code
Converting code
by janesmouse on Mon Mar 30, 2020 9:52 am
Pretty new at using Circuitpython
I am trying to get the Fancyled code used in the Glow Fur Scarf project to work on the CPB board using the board Neopixels. I also want to use tapping to change patterns. How do I change Gemma M0 specific code to work on the CPB, my attempts so far are failing.
Thanks in advance
janesmouse
Re: Converting code
by dastels on Mon Mar 30, 2020 10:22 am
What have you tried, and what is it doing (or not doing)?
dastels
Re: Converting code
by janesmouse on Mon Mar 30, 2020 11:51 am
Hi Dave,
I have changed the reference for the neopixels to
pixels = neopixel.NeoPixel(board, 10, brightness=0.3, auto_write=False)
and added the board and Neopixel libraries also changed references for strip to pixels and num_leds to 10.
Not sure if all of that has worked as I can;t get my head around the button press code well enough to change it to use the accelerometer Tap to trigger pattern change.
Emily
janesmouse
Re: Converting code
by dastels on Mon Mar 30, 2020 1:01 pm
The first argument to neopixel.Neopixel should be board.NEOPIXEL which is the pin connected to the NeoPixels. Search https://learn.adafruit.com/ for projects using digital inputs and the accelleroneter. Specifically, look at the CPB tutorial: https://learn.adafruit.com/adafruit-circuit-playground-bluefruit
dastels
