Imageloader TFT Gizmo
by elputnam on Sat Apr 04, 2020 5:51 pm
I am trying to run the imageloader_tft_gizmo example through Arduino with a CPX, but I receive the following error message:
[code]imageloader_tft_gizmo:59:10: error: 'class Serial_' has no member named 'printf'; did you mean 'print'?
I have not modified the code and I am using Windows 10.
elputnam
Re: Imageloader TFT Gizmo
by adafruit_support_carter on Mon Apr 06, 2020 12:33 pm
What Board do you have selected in the Arduino IDE under Tools -> Board?
by elputnam on Mon Apr 06, 2020 1:42 pm
Circuit Playground Express
elputnam
by adafruit_support_carter on Mon Apr 06, 2020 5:43 pm
I tried to investigate this and I couldn't even get as far as you could. Can you try the simple example I posted here and see if you get the same behavior?
https://github.com/adafruit/Adafruit_Arcada/issues/33
by elputnam on Wed Apr 08, 2020 11:28 am
I tried the code you sent, but it did not work. Here is the error message:
Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Board: "Adafruit Circuit Playground Express"
In file included from sketch\AracadaTest.ino.cpp:1:0:
C:\Users\0123213s\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.6\cores\arduino/Arduino.h:124:0: warning: "digitalPinToInterrupt" redefined
#define digitalPinToInterrupt(P) ( P )
In file included from C:\Users\0123213s\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.6\cores\arduino/delay.h:23:0,
from C:\Users\0123213s\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.6\cores\arduino/Arduino.h:81,
C:\Users\0123213s\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.6\variants\circuitplay/variant.h:57:0: note: this is the location of the previous definition
#define digitalPinToInterrupt(P) (g_APinDescription[P].ulExtInt)
In file included from C:\Users\0123213s\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/Operators/VariantCasts.hpp:7:0,
from C:\Users\0123213s\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/Operators/VariantOperators.hpp:7,
from C:\Users\0123213s\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/Variant/VariantRef.hpp:12,
from C:\Users\0123213s\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/Array/ArrayIterator.hpp:8,
from C:\Users\0123213s\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/Array/ArrayRef.hpp:8,
from C:\Users\0123213s\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson.hpp:17,
from C:\Users\0123213s\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson.h:9,
from C:\Users\0123213s\Documents\Arduino\libraries\Adafruit_Arcada_Library/arcadatype.h:15,
from C:\Users\0123213s\Documents\Arduino\libraries\Adafruit_Arcada_Library/Boards/Adafruit_Arcada_CircuitPlaygroundExpress.h:29,
from C:\Users\0123213s\Documents\Arduino\libraries\Adafruit_Arcada_Library/Adafruit_Arcada.h:20,
from C:\Users\0123213s\Desktop\CircuitPlayground\AracadaTest\AracadaTest.ino:1:
C:\Users\0123213s\Documents\Arduino\libraries\ArduinoJson\src/ArduinoJson/Polyfills/attributes.hpp:18:0: warning: "DEPRECATED" redefined
#define DEPRECATED(msg) __attribute__((deprecated(msg)))
In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:23:0,
from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3,
from C:\Users\0123213s\Documents\Arduino\libraries\Adafruit_Arcada_Library/Boards/Adafruit_Arcada_CircuitPlaygroundExpress.h:2,
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\libraries\Adafruit_Circuit_Playground/utility/Adafruit_CPlay_Mic.h:10:0: note: this is the location of the previous definition
#define DEPRECATED(func) func __attribute__ ((deprecated))
In file included from C:\Users\0123213s\Documents\Arduino\libraries\Adafruit_Arcada_Library/Adafruit_Arcada.h:20:0,
C:\Users\0123213s\Documents\Arduino\libraries\Adafruit_Arcada_Library/Boards/Adafruit_Arcada_CircuitPlaygroundExpress.h: In member function 'virtual void Adafruit_Arcada::displayBegin()':
C:\Users\0123213s\Documents\Arduino\libraries\Adafruit_Arcada_Library/Boards/Adafruit_Arcada_CircuitPlaygroundExpress.h:5:24: error: 'SPI1' was not declared in this scope
#define ARCADA_TFT_SPI SPI1
C:\Users\0123213s\Documents\Arduino\libraries\Adafruit_Arcada_Library/Boards/Adafruit_Arcada_CircuitPlaygroundExpress.h:50:49: note: in expansion of macro 'ARCADA_TFT_SPI'
Adafruit_ST7789 *tft = new Adafruit_ST7789(&ARCADA_TFT_SPI, ARCADA_TFT_CS,
C:\Users\0123213s\Documents\Arduino\libraries\Adafruit_Arcada_Library/Boards/Adafruit_Arcada_CircuitPlaygroundExpress.h:5:24: note: suggested alternative: 'SPI'
exit status 1
Error compiling for board Adafruit Circuit Playground Express.
elputnam
by adafruit_support_carter on Thu Apr 09, 2020 11:10 am
In your case it looks like something may be happening with your Arduino installation. Are you able to load a basic Blink example OK?
