How to use CP Express sensory data with other program.
by ClericMT on Mon May 11, 2020 11:58 am
I am using CircuitPython with my Circuit Playground Express connected to Raspberry Pi 4 via USB.
I have some servo motors connected to the rPi's GPIO pins and I would like them to respond to the sensory data given from the Circuit Playground
(i.e when a certain frequency detected through the sound sensor the servo motor runs forward)
What is the best way to go about this? I can see the sensory data in the CircuitPython REPL but I can't use the information to control the servo motors
ClericMT
Re: How to use CP Express sensory data with other program.
by mikeysklar on Mon May 11, 2020 2:04 pm
Hi ClericMT,
There is probably multiple ways to pull data from your CPX into the RPI. I think the most elegant solution is to use the filesytem of your CPX to log the sound sensor data. You can open a file from the CPX script write it to the USB mounted CPX drive which your Raspberry Pi system can also read from. Your RPI could have a program running that is constantly checking the mounting CPX USB sensory file.
Here is a link showing what your CPX code.py and boot.py will need to have added so that you can write to the filesystem.
https://learn.adafruit.com/adafruit-cir ... on-storage
mikeysklar
by ClericMT on Tue May 12, 2020 4:29 am
Perfect that is what I was looking for. Thanks
ClericMT
