Adding NeoPixel string to the playground
Re: Adding NeoPixel string to the playground
by dastels on Thu Jun 25, 2020 8:24 pm
Can you paste the full error output so I can see the context. Thanks!
dastels
by Spolyoka1 on Fri Jun 26, 2020 6:12 pm
Hey,
Thanks again 1st posting is the code as is. Second is the Error Message.
Code:
#include <string.h>
#include <Arduino.h>
#include <SPI.h>
#include "Adafruit_BLE.h"
#include "Adafruit_BluefruitLE_SPI.h"
#include "Adafruit_BluefruitLE_UART.h"
#include "BluefruitConfig.h"
#if SOFTWARE_SERIAL_AVAILABLE
  #include <SoftwareSerial.h>
#endif
#include <Adafruit_CircuitPlayground.h>
// Configuration (you don't need to change these, but can!):
#define FACTORYRESET_ENABLE     1   // Set to 1 to factory reset the Bluefruit LE
                                    // module.  In general this is a smart idea to
                                    // put the module into a known good state.
                                    // A value of 1 means perform a factory reset
                                    // on start, and 0 means no factory reset.
#define NUMPIXELS               10  // Number of NeoPixels on the board.
#define BRIGHTNESS              255 // NeoPixel brightness (0...255, low to max brightness)
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1:
#define LED_PIN    6
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT 20
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
// Create the bluefruit object, for Circuit Playground this needs to be
// hardware serial.
Adafruit_BluefruitLE_UART ble(BLUEFRUIT_HWSERIAL_NAME, BLUEFRUIT_UART_MODE_PIN);
// A small helper
void error(const __FlashStringHelper*err) {
  Serial.println(err);
  while (1);
// function prototypes over in packetparser.cpp
uint8_t readPacket(Adafruit_BLE *ble, uint16_t timeout);
float parsefloat(uint8_t *buffer);
void printHex(const uint8_t * data, const uint32_t numBytes);
// the packet buffer
extern uint8_t packetbuffer[];
// Offset that controls which pixels are turned on/off.
// Pressing the left/right controller button moves this offset
// up/down and 'slides' the chain of 10 pixels around.
int currentOffset = 0;
// Last selected color.
uint8_t currentRed, currentGreen, currentBlue;
// Light up a chain of 10 pixels starting at offset global variable value.
void lightPixels(uint8_t red, uint8_t green, uint8_t blue, int offset) {
  CircuitPlayground.strip.clear();
  for (int i = offset; i < offset+NUMPIXELS; ++i) {
    if ((i >= 0) && (i < NUMPIXELS)) {
      CircuitPlayground.strip.setPixelColor(i, red, green, blue);
  CircuitPlayground.strip.show();
   strip.clear();
  for (int i = offset; i < offset+LED_COUNT; ++i) {
    if ((i >= 0) && (i < LED_COUNT)) {
  strip.show();
  // Wait for serial port before starting.  Not required but helps with debugging.
  //while (!Serial);
  //delay(500);
  // Initialize Circuit Playground library and turn off the Pixels.
  CircuitPlayground.begin(BRIGHTNESS);
  CircuitPlayground.clearPixels();
  // Initialize serial output.
  Serial.begin(115200);
  Serial.println(F("Adafruit Circuit Playground Bluefruit Neopixel Color Picker Example"));
  Serial.println(F("-------------------------------------------------------------------"));
  // Initialise the module
  Serial.print(F("Initialising the Bluefruit LE module: "));
  if ( !ble.begin(VERBOSE_MODE) )
    error(F("Couldn't find Bluefruit, make sure it's in DATA mode & check wiring...."));
  Serial.println( F("OK!") );
  if ( FACTORYRESET_ENABLE )
    // Perform a factory reset to make sure everything is in a known state
    Serial.println(F("Performing a factory reset: "));
    if (!ble.factoryReset()) {
      Serial.println(F("Couldn't factory reset, making another attempt..."));
      delay(1000);
        error(F("Couldn't factory reset!"));
  // Disable command echo from Bluefruit
  ble.echo(false);
  Serial.println("Requesting Bluefruit info:");
  // Print Bluefruit information
  ble.info();
  // Change advertised name to Circuit_Playground_BLE
  ble.println("AT+GAPDEVNAME=CPlay_BLE");
  delay(100);
  ble.println("ATZ");
  delay(100);
  Serial.println(F("Please use Adafruit Bluefruit LE app to connect in Controller mode"));
  Serial.println(F("Then activate/use the sensors, color picker, game controller, etc!"));
  Serial.println();
  ble.verbose(false);  // debug info is a little annoying after this point!
  // Wait for connection
  while (! ble.isConnected()) {
      delay(500);
  Serial.println(F("***********************"));
  // Set Bluefruit to DATA mode
  Serial.println( F("Switching to DATA mode!") );
  ble.setMode(BLUEFRUIT_MODE_DATA);
void loop()
  /* Wait for new data to arrive */
  uint8_t len = readPacket(&ble, BLE_READPACKET_TIMEOUT);
  if (len == 0) {
    return;
  /* Got a packet! */
  //printHex(packetbuffer, len);
  // Color
  if (packetbuffer[1] == 'C') {
    // Parse out the red, green, blue values and save them.
    uint8_t red = packetbuffer[2];
    uint8_t green = packetbuffer[3];
    uint8_t blue = packetbuffer[4];
    // Change the color.
    currentRed = red;
    currentGreen = green;
    currentBlue = blue;
  // Left/right adjust the offset that turns on/off pixels.
  if (packetbuffer[1] == 'B') {
    if (memcmp(packetbuffer, "!B705", 5) == 0) {
      // Left button release.
      currentOffset -= 1;
    else if (memcmp(packetbuffer, "!B804", 5) == 0) {
      // Right button release.
      currentOffset += 1;
    currentOffset = constrain(currentOffset, -NUMPIXELS, NUMPIXELS);
  // Update the pixels again since either the color or offset position
  // must have changed above.
  lightPixels(currentRed, currentGreen, currentBlue, currentOffset);
Error:
Arduino: 1.8.13 (Windows Store 1.8.39.0) (Windows 10), Board: "Adafruit Circuit Playground"
C:\Users\Spoly\AppData\Local\Temp\cc8AF9jn.s: Assembler messages:
C:\Users\Spoly\AppData\Local\Temp\cc8AF9jn.s:11932: Error: symbol `headD' is already defined
C:\Users\Spoly\AppData\Local\Temp\cc8AF9jn.s:12067: Error: symbol `headB' is already defined
C:\Users\Spoly\AppData\Local\Temp\cc8AF9jn.s:12172: Error: symbol `headC' is already defined
C:\Users\Spoly\AppData\Local\Temp\cc8AF9jn.s:12276: Error: symbol `headF' is already defined
C:\Users\Spoly\AppData\Local\Temp\cc8AF9jn.s:12374: Error: symbol `head20' is already defined
C:\Users\Spoly\AppData\Local\Temp\cc8AF9jn.s:12388: Error: symbol `nextbyte20' is already defined
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.39.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/program files/windowsapps/arduinollc.arduinoide_1.8.39.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/7.3.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Adafruit Circuit Playground.
Spolyoka1
by dastels on Fri Jun 26, 2020 6:51 pm
These errors are from the assembler. Do you have all the board support packages and libraries up to date?
dastels
by Spolyoka1 on Fri Jun 26, 2020 9:07 pm
I think so, I have the libraries I have listed below.
Adafruit_bluefruitLE_nRF51
Adafruit_NeoPixel
Not sure if there are any library collections you would suggest downloading?
Spolyoka1
by dastels on Fri Jun 26, 2020 11:07 pm
I mean are they up to date. Go into the board manager and library manager and select updateable from the type dropdown menu. Update any that are listed.
dastels
by Spolyoka1 on Sat Jun 27, 2020 3:26 pm
Sorry, Yes I believe so I went to the library manager and checked they were all the most recent versions. It couldn't be too big a file could it?
Another option that would work is if I can just get the strip to light up I can recreate the circle of LEDS so it doesn't have to light both the strip and Board LEDS. Would that work?
Spolyoka1
by dastels on Sat Jun 27, 2020 5:01 pm
Unlikely it's a space issue. You're working in C++ so you can fit A LOT of code. I expect you'd get something more to the point if you were out of space. I've never actually seen an assembler error in this context. I'll ask around.
dastels
by Spolyoka1 on Wed Jul 01, 2020 12:35 pm
Hey Dave,
Thanks again for digging into this. Was anyone able to provide some insight?
Best,
Spolyoka1
by dastels on Wed Jul 01, 2020 1:40 pm
Nothing yet.
dastels
by Spolyoka1 on Wed Jul 08, 2020 11:59 pm
Hey,
So I think that for my needs the feather is a better board to try and program. Currently I have the Feather M0 with Bluefruit. I am able to upload the feather bluefruit animation controller sketch and it somewhat works. The LED is very flickery and the color selection is a little delayed. I have it wired from 3V to Power in, Gnd to Gnd, and Pin 6 to data in. Not sure if its a power issue with the 3v instead of 5. I tried it wired to the USB power instead of the 3v and it gives the same result. Any thoughts?
Spolyoka1
by dastels on Thu Jul 09, 2020 11:53 am
Not offhand. Flickery neopixels is often a power issue.
dastels
by adafruit_support_carter on Sat Jul 18, 2020 8:07 pm
#endif
The CircuitPlayground Arduino library has its own NeoPixel implementation. So you don't want to import the standard NeoPixel library for your external NeoPixel strand. We've added a new example to the library to hopefully demonstrate how to do this:
https://github.com/adafruit/Adafruit_Ci ... pixels.ino
