Sending UART messages
by rdevries on Tue Jun 23, 2020 4:05 pm
I am trying to send a message over a UART.
What I need to do is send a command, value, then a terminator.
If I enter the value as a constant it will work.
end_cmd = bytearray([0xFF,0xFF,0xFF])
DispUart.write(b'r1et.val='+ b'18' + end_cmd)
If I want to send a variable it doesn't.
DispUart.write(b'r1et.val='+ bytes(SumV) + end_cmd)
If I use
SumV = 18
print("Write ETime - ",SumV," ")
print(bytes(SumV))
I get
Write ETime -  18
b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
If I try to convert the int to a string
SumV = '123'
DispUart.write(b'r1et.val='+ SumV + end_cmd)
Works, but if I try
SumV = str(Vr1tc_val)
Doesn't work.
What would the issue be?
Where can I find more examples of code snipits for the commands I am trying to use? (str, byte(), etc.)
Thank you
rdevries
Re: Sending UART messages
by mikeysklar on Tue Jun 23, 2020 5:52 pm
This serial input basics thread is excellent.
https://forum.arduino.cc/index.php?topic=396450.0
mikeysklar
by rdevries on Tue Jun 23, 2020 8:16 pm
Thank you, I will have to have a look at that post closer.
And now I see that I am in the wrong forum.
rdevries
