Odd Bug - analogRead() sets pin to Low
by climbingNinja on Sun Jul 12, 2020 12:43 am
I am working on creating a debugging tool for the Circuit Playground Express and have come across on odd bug when I try to read the current state of the microcontroller. I have a loop that checks each digital pin and analog pin for it's current value and transmits it to the Serial port (to be processed by another program). But I have found that the Express will permanently set a pin off/low if an analogRead() is performed on a pin that has been set to high. For example:
  pinMode(2, OUTPUT);
  digitalWrite(2, HIGH);
  digitalWrite(2,HIGH);
  delay(200);
  analogRead(A5);//A5 shares the same location as D2
  delay(200);
Also if I use the analog constants, I get the same bug:
  pinMode(A5, OUTPUT);
  digitalWrite(A5, HIGH);
  digitalWrite(A5,HIGH);
  delay(200);
  analogRead(A5);
  delay(200);
This code works fine on the Classic but for some reason with the express if I perform an analogRead(), the pin shuts off and will no longer turn on (i.e. this isn't blinking on/off, it just stays off). Also, I've tried this code on two separate Express boards, so I assume this is not a bug specific to my board but a general issue with the Express.
Any suggestions for how to safely read the analog pins? Or anyone know why this is happening?
climbingNinja
Re: Odd Bug - analogRead() sets pin to Low
by westfw on Sun Jul 12, 2020 3:25 am
When you do an analogRead() of a pin, it switches the pin into analog input mode. You probably have to do pinMode(pin, OUTPUT) again to get it back into digital output mode.
The Circuit Playgroup Classic has a differnt CPU chip and core, which perhaps behaves slightly differently, but I don't think either way is actually "wrong." Using the explicit pinMode() should work on all boards (and having digitalWrite() explicitly check and switch modes would slow down a function already famous for being slower than it should be.)
westfw
by climbingNinja on Sun Jul 12, 2020 2:28 pm
Thanks westfw! You're correct, it is a pinMode issue. If I toggle the pinMode, the LED blinks on/off. I'll have to work on a different method for the Playground to check all the analog pin values.
#include <Adafruit_CircuitPlayground.h>
  Serial.begin(9600);
  CircuitPlayground.begin();
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  pinMode(2, OUTPUT);
  Serial.println("ON");
  pinMode(2, OUTPUT);
  delay(200);
  Serial.println("OFF");
  analogRead(A5);
  delay(200);
climbingNinja
by kevinjwalters on Tue Jul 28, 2020 10:50 am
Not exactly the same thing, but there's a previous discussion which eventually heads towards pinMode() on A0 on CPX and Arduino Forum: Arduino Zero DAC (Analog Output) Cutoff Below the Rail Voltage. One's expectations need to be calibrated when it comes to portability of code and api behaviour between boards.
I also find some of the terminology used confusing at times. Digital pwm outputs are sometimes referred to as analog outputs and things like "true analog output" gets used if a DAC is involved.
kevinjwalters
