CPX Board Is Not Functioning
- dheub
So when plugging in my CPX, the red D13 LED will flash a couple of times and the green "On" indicator will light up for about half a second. They then turn off and the board is unresponsive. Also, I can no longer see the board show up under file explorer on my computer. Is there something that could be causing this?
- dastels
Re: CPX Board Is Not Functioning
Did it work prior to this behavior?
- dheub
It did. I have no real reason to explain why it stopped working. At one point my code ran, now it does not.dastels wrote:Did it work prior to this behavior?
- dastels
Check all over for shorts. It could have picked up a bit of conductive material.
The green "on" LED is on if the board has power. It sounds like your computer is shutting down the USB port. That usually happens when there's too much current draw. And a short could easily cause that. Also, is anything connected to the board that could be using excessive current?
- dheub
There's nothing at all connected to the board to draw current. I also do not see any indication on the board that anything is shorted, like a blown chip, smoke or deposits.
- dastels
Have you tried a different USB port?
- dastels
Also, there may not be damage resulting from a short. I was thinking more of looking for bits of wire stuck to the board.
- dheub
I see what you're saying. I haven't wired anything to the board ever, nor is there any metallic debris on it. I have tried different USB ports, and different computers. So I do not believe that would be the issue.
- dastels
When did you buy it?
- dheub
It was ordered on 9/12/2020
- dastels
OK, let's get you a new one. Please email [email protected] with a link to this thread, your order number, and request the replacement of CircutPlayground Express.
- dheub
Oh okay. Awesome. Thank you so much!
- PureWeen
Was the cause of this ever found out? I've hit a similar problem. I feel like I must have damaged something on the board . Board was working fine all day and then it stopped. The green light will turn on briefly and then board shuts off. If I turn it on via the JST plugin then it doesn't turn off but the ATMEL chip gets too hot to touch (not sure if it's like that during normal operations as well)
If I let the chip sit for a bit then I can plugin the USB and it'll stay on for about 5 seconds. I deleted the code.py file during one of these small windows to see if that would resolve the issue and it doesn't seem to. I've noticed that it gets really hot directly under the JST connection when I plug in the USB
I'm guessing I accidently shorted something while trying to wire up the MIDI feather wing to it. I've unhooked everything from the board as well while trying to get it to boot back up.
- dastels
It does sound like a short, though the difference in behavior between powering via USB and Battery is odd. They each go through a diode but it's the same after that. The battery is a lower voltage which may account for the difference, but it's still odd.
SHutting down could be the fuse kicking in, and anything heating up unusually is often the sign of too much current (i.e. due to a short).
I've not seen or heard of that behavior before.
