CPX hangs when using mic and speaker together
Play with it! Please tell us which board you're using.
ronturcotte
Post by ronturcotte »
(deleted and reposted with properly formatted code)
I'm building an application that requires both the microphone and the speaker on a Circuit Playground Express. The code works if I use EITHER the mic or the speaker, but everything freezes when I try to use both. The problem is easy to reproduce - I just start with the code from this page: https://learn.adafruit.com/sensor-plott ... thon/sound, add an import for circuitplayground and a call to cp.play_tone:
import array
import math
import time
import audiobusio
import board
from adafruit_circuitplayground import cp
def mean(values):
    return sum(values) / len(values)
def normalized_rms(values):
    minbuf = int(mean(values))
    sum_of_samples = sum(
        float(sample - minbuf) * (sample - minbuf)
        for sample in values
    return math.sqrt(sum_of_samples / len(values))
mic = audiobusio.PDMIn(
    board.MICROPHONE_CLOCK,
    board.MICROPHONE_DATA,
    sample_rate=16000,
    bit_depth=16
samples = array.array('H', [0] * 160)
mic.record(samples, len(samples))
while True:
    magnitude = normalized_rms(samples)
    print(((magnitude),))
    cp.play_tone(440,.25)
    time.sleep(0.1)
I'm using CircuitPython 6.1.0. Does anyone know why this is happening?
mikeysklar
Re: CPX hangs when using mic and speaker together
Post by mikeysklar »
@ronturcotte,
Could you try running our "Interactive Scream" example which is using the mic and playback at the same time.
https://learn.adafruit.com/the-scream-m ... cuitpython
import time
import math
import array
import audiobusio
import audioio
import audiocore
import board
from adafruit_crickit import crickit
# Number of samples to read at once.
NUM_SAMPLES = 160
# Remove DC bias before computing RMS.
    samples_sum = sum(
    return math.sqrt(samples_sum / len(values))
def mean(values):
mic = audiobusio.PDMIn(board.MICROPHONE_CLOCK, board.MICROPHONE_DATA,
                       sample_rate=16000, bit_depth=16)
# Record an initial sample to calibrate. Assume it's quiet when we start.
samples = array.array('H', [0] * NUM_SAMPLES)
head_servo = crickit.servo_1
head_servo.set_pulse_width_range(min_pulse=500, max_pulse=2500)
head_servo.angle = 90  # center the head.
# Set audio out on speaker.
a = audioio.AudioOut(board.A0)
# Start playing the file (in the background).
def play_file(wavfile):
    print("Playing scream!")
    with open(wavfile, "rb") as f:
        wav = audiocore.WaveFile(f)
        a.play(wav)
        while a.playing:
            head_servo.angle = 60
            time.sleep(.01)
            head_servo.angle = 120
            time.sleep(.01)
while True:
    print(((magnitude),))  # formatting is for the Mu plotter.
    if magnitude < 1000:  # it's quiet, do nothing.
        pass
    else:
        print("LOUD")
        time.sleep(.05)
        time.sleep(.05)
        time.sleep(.02)
        play_file("scream_low.wav")
        time.sleep(2)
MarcBaum
Post by MarcBaum »
Here the same, running "Interactive Scream" example. CPX+crickit hangs after playing the wave file with "adafruit-circuitpython-circuitplayground_express_crickit-de_DE-6.3.0". Some Ideas?
Marc
mikeysklar
Interesting that both of our chunk of example code cause the hang.
Were you using the CPX + Crickit in both scenarios? Do you see thing hang if you remove the crickit?
I see you have been good about staying current with the CircuitPython release updates. Have you also removed all the older /lib libraries and replaced them with the updated 6.3 library release?
https://circuitpython.org/libraries
Since you are seeing example code hanging I'm guessing that an older library might be used which can be problematic with a newer CircuitPython release.
MarcBaum
Post by MarcBaum »
thank you for yor helph
I using the CPX with and without the Crickit. It hang in both szenario, but the code works without playing any wave file. (#)
The error arises when I use the microphone and the sound output
The lib folder ist empty, there no olds libarys.
mikeysklar
@MarcBaum,
Let's make sure you bootloader is current and that the adafruit_circuitplayground library is indeed in your CIRCUITPY/lib folder as that should be necessary for the import line of your example code.
The current bootloader version for the CPX is:
https://github.com/adafruit/uf2-samdx1/ ... 3.13.0.uf2
# from the 20210616 CircuitPython 6.3 library bundle - this folder needs to be in your CIRCUITPY/lib
$ find adafruit_circuitplayground/
adafruit_circuitplayground//__init__.mpy
adafruit_circuitplayground//express.mpy
adafruit_circuitplayground//bluefruit.mpy
adafruit_circuitplayground//circuit_playground_base.mpy
MarcBaum
Post by MarcBaum »
@mikeysklar
The bootloader ist current (3.13). I moved the library file to the LIB folder but had the same problem. After playing the WAVE file the CPX hangs. When i use the led instead of audio, all works finet with his code.
import time
import math
import array
import audiobusio
import audioio
import audiocore
import board
import digitalio
NUM_SAMPLES = 160
led = digitalio.DigitalInOut(board.LED)
led.direction = digitalio.Direction.OUTPUT
samples_sum = sum(
def mean(values):
a.play(wav)
while a.playing:
time.sleep(.01)
time.sleep(.01)
while True:
if magnitude < 14000: # it's quiet, do nothing.
led.value = False
else:
print("LOUD")
led.value = True
time.sleep(.05)
time.sleep(.05)
time.sleep(.02)
# play_file("scream_low.wav")
time.sleep(2)
mikeysklar
This is still concerning that the CPX hangs after playing the audio file. I wonder if it could be a memory issue?
Have you tried running the CircuitPython 7.0.0-alpha3 (and updating the necessary libraries). I suspect the issue is still there.
https://circuitpython.org/board/circuit ... d_express/
There is an open issue for the CPX hanging when a WAV file is played and mic.record is being used.
https://github.com/adafruit/circuitpython/issues/4600
This was working with CircuitPython 5.x
MarcBaum
Post by MarcBaum »
On CircuitPython 7.0.0-alpha3 and updated the libraries the same. CPX still hanging
mikeysklar
@MarcBaum,
Thank you for taking the time that the current CircuitPython alpha release and libs still show the hang. If you would like to add a comment on the open github issue I think it would be relevant and helpful. It is an open issue.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
