Capacitive Touch on CPX 'Floats' on touch
by notaquestion on Wed Feb 03, 2021 2:23 am
Hi Folks,
I've recently purchased some Circuit Playground Expresses to use with a project I wrote on a CPB. I'm working in Arduino.
I've noticed the Capacitive Touch isn't working the same way? The reading oscillates from 0 to 1000 rapidly when I touch an alligator clip connected to a pad, and osilates a little just from having the clip connected. This seems to happen on every pad.
I found a way to turn the oscillation into a signal, but this isn't something I had to do on the CPB.
Fun bonus fact, if I touch the Ground pads, everything works like normal, i.e. like it did on the CPB, if with a smaller numerical range.
Any idea what could be different/what I'm doing wrong?
notaquestion
Re: Capacitive Touch on CPX 'Floats' on touch
by adavid7 on Wed Feb 03, 2021 11:57 am
Have you issued a calibrate command for the touch pad you are using in your setup() method?
I haven't used the CPX touch pads with the Arduino, only MakeCode, but I imagine that exists in the Arduino library also. You have to calibrate whenever you change what you have connected to the touch pad.
adavid7
by notaquestion on Thu Feb 04, 2021 2:29 am
I've read through Adafruit_Circuit_Playground.h and .cpp, but I wasn't able to find any calibrate command. I have reset the device several times since clipping on the aligator clip, and the problem happens independently of the alligator clip, so I don't think calibration is the source of the issue.
While looking for a calibrate function though, I did notice that the CPX uses Adafruit_CPlay_FreeTouch while the CPB used CPlay_CapacitiveSensor, so maybe the difference is related to that?
The Freetouch stuff is a bit over my head however... I'm still stuck unsure why things are different.
notaquestion
by adavid7 on Thu Feb 04, 2021 11:33 pm
I don't know how the libraries are structured and haven't explored them, but in both the JavaScript and Python libraries in MakeCode, I see a method called "input.touch_a1.calibrate()".
Surely that "input" class must also exist in the Arduino library?
adavid7
by notaquestion on Thu Feb 11, 2021 1:28 am
I really don't think there is a calibrate function.
Also, I'm not using a function to get touches, I'm using it to get a raw capacitive reading. I can check to see if that goes over the threshold myself, but the Raw readings themselves seem wacky.
Here's the public functions from Adafruit_CircuitPlayground.h
bool begin(uint8_t brightness = 20);
  Adafruit_CPlay_NeoPixel strip;  ///< the neopixel strip object
  Adafruit_CPlay_LIS3DH lis;      ///< the accelerometer object
  Adafruit_CPlay_Mic mic;         ///< the microphone object
  Adafruit_CPlay_Speaker speaker; ///< the speaker object
#if defined(__AVR__) ||                                                        \
    defined(ARDUINO_NRF52840_CIRCUITPLAY) // Circuit Playground 'classic' or
                                          // bluefruit
  CPlay_CapacitiveSensor cap[8]; ///< the array of capacitive touch sensors
#else
  Adafruit_CPlay_FreeTouch cap[7]; ///< the array of capacitive touch sensors
  IRrecvPCI irReceiver;            ///< the IR receiver object
  IRdecode irDecoder;              ///< the IR decoder object
  IRsend irSend;                   ///< the IR send object
#endif
  bool slideSwitch(void);
  void redLED(bool v);
  void playTone(uint16_t freq, uint16_t time, bool wait = true);
  bool leftButton(void);
  bool rightButton(void);
  uint16_t lightSensor(void);
  int16_t soundSensor(void);
  float temperature(void);
  float temperatureF(void);
  uint16_t readCap(uint8_t p, uint8_t samples = 10);
  // Accelerometer
  float motionX(void);
  float motionY(void);
  float motionZ(void);
  void setAccelRange(lis3dh_range_t range)
  void setAccelTap(uint8_t c, uint8_t clickthresh)
  uint8_t getAccelTap(void)
  void clearPixels(void)
  void setPixelColor(uint8_t p, uint32_t c)
  void setPixelColor(uint8_t p, uint8_t r, uint8_t g, uint8_t b)
  void setBrightness(uint16_t b)
  uint8_t sine8(uint8_t x)
  uint8_t gamma8(uint8_t x)
  uint32_t colorWheel(uint8_t x);
  void senseColor(uint8_t &red, uint8_t &green, uint8_t &blue);
  uint32_t senseColor()
  bool isExpress(void);
And here are the public functions from Adafruit_CPlay_FreeTouch.h
public:
  Adafruit_CPlay_FreeTouch(int p = 0, oversample_t f = OVERSAMPLE_4, series_resistor_t r = RESISTOR_0, freq_mode_t fh = FREQ_MODE_NONE);
  bool begin(void);
  uint16_t measure(void);
  uint16_t measureRaw(void);
Let me know if I'm missing a calibrate in there? Maybe it's named something I'm not familiar with?
notaquestion
by adavid7 on Thu Feb 11, 2021 1:44 am
I'm not sure. I've not used those libraries. In MakeCode there is this calibrate method. I just assumed something similar would be in the C++ version, but I don't know much about it.
adavid7
by adafruit_support_carter on Thu Feb 11, 2021 4:26 pm
The raw readings can vary from board to board given the different nature of the cap touch hardware.
Are you using the readCap() function?
http://adafruit.github.io/Adafruit_Circ ... e65bd1e923
It has a parameter that let's you adjust the number of samples used to compute an averaged value.
by notaquestion on Sat Feb 13, 2021 7:02 pm
Hi Carter,
Thank you for replying!
I tried adjusting the samples, but it seems like they're not hooked up to anything in Adafruit_CircuitPlayground.cpp if you're using the express.
  uint16_t Adafruit_CircuitPlayground::readCap(uint8_t p, uint8_t samples) {
    defined(ARDUINO_NRF52840_CIRCUITPLAY) // Circuit Playground Classic or
                                          // bluefruit
  switch (p) {
  case 0:
    return cap[0].capacitiveSensor(samples);
#elif defined(__SAMD21G18A__) // Circuit Playground Express
  // analog pins r ez!
  if ((p >= A1) && (p <= A7)) {
    return cap[p - A1].measure();
  // oof digital pins
  switch (p) {
  case 0:
    return cap[A6 - A1].measure();
  case 1:
#endif
The measure function it is using Adafruit_CPlay_FreeTouch, declared here.
for (int i = 0; i < 7; i++) {
    cap[i] = Adafruit_CPlay_FreeTouch(A1 + i, OVERSAMPLE_4, RESISTOR_50K,
                                      FREQ_MODE_NONE);
    if (!cap[i].begin())
      return false;
And that takes no paramaters...
uint16_t Adafruit_CPlay_FreeTouch::measure(void) {
  uint16_t m;
  m = measureRaw();
  if (m == -1) return -1;
  // normalize the signal
  switch (oversample) {
    case OVERSAMPLE_1:   return m;
    case OVERSAMPLE_2:   return m/2;
    case OVERSAMPLE_4:   return m/4;
    case OVERSAMPLE_8:   return m/8;
    case OVERSAMPLE_16:  return m/16;
    case OVERSAMPLE_32:  return m/32;
    case OVERSAMPLE_64:  return m/64;
  return -1; // shouldn't reach here but fail if we do!
Maybe the answer is in one of these? Nothings commented though so I'm not sure what they actually do.
// set up sense resistor
  setSeriesResistor(seriesres);
  // set up prescalar
  setOversampling(oversample);
  // set up freq hopping
  setFreqHopping(freqhop, hops);
  // set up compensation cap + int (?) cap
  setCompCap(compcap);
  setIntCap(intcap);
notaquestion
by adafruit_support_carter on Mon Feb 15, 2021 12:44 pm
Seems like maybe it should? Opened an issue for this here:
https://github.com/adafruit/Adafruit_Ci ... /issues/61
by notaquestion on Mon Feb 22, 2021 12:54 am
Any sense of when we may get a reply to the github issue?
I've ordered some of the CPBluefruit versions because I know they don't have this issue, but now I have a couple of CPX I don't currently have a use for.
notaquestion
by flyingcheesehead on Fri Feb 26, 2021 11:27 pm
notaquestion wrote:I've noticed the Capacitive Touch isn't working the same way? The reading oscillates from 0 to 1000 rapidly when I touch an alligator clip connected to a pad, and osilates a little just from having the clip connected. This seems to happen on every pad.
I'm getting something similar! viewtopic.php?f=58&t=175832&p=857516#p857516
I don't have a solution, unfortunately, but you're not alone. Really hope this gets resolved soon as it's no fun to have gadgets that don't work right.
flyingcheesehead
