Big Sur DISK NOT EJECTED PROPERLY madness
by adavid7 on Sat Feb 13, 2021 6:26 pm
Ever since I upgraded to macOS Big Sur, I have found that the harmless "DISK NOT EJECTED PROPERLY" notifications after each download are rather persistent, and require manually dismissing each one. This madness is driving me crazy. Does anyone have a solution to either suppressing them or at least dismissing them all at once?
eject madness.png (364.15 KiB) Viewed 154 times
adavid7
Re: Big Sur DISK NOT EJECTED PROPERLY madness
by mikeysklar on Mon Feb 15, 2021 5:03 pm
This should disable the message, but will only last until the next reboot. It shuts up the UserNotificationCenter so you might miss some helpful messages.
sudo launchctl unload -w /System/Library/LaunchDaemons/com.apple.UserNotificationCenter.plist
mikeysklar
by adavid7 on Mon Feb 15, 2021 11:27 pm
Oh, thanks. Too bad you can't control which of those system notifications you want or don't want, like you can with other apps' notifications.
adavid7
by mikeysklar on Tue Feb 16, 2021 4:51 pm
@adavid7,
This might have changed a bit in BigSur, but on my Mojave MacOS box (10.14) I can go to:
Apple --> System Preferences --> Notifications
and customize alerts and do not disturbs, etc.
Screen Shot 2021-02-16 at 12.49.28 PM.png (438.73 KiB) Viewed 119 times
mikeysklar
by adavid7 on Tue Feb 16, 2021 6:35 pm
Right @mikeysklar. It's the same in Big Sur, but these notifications are system ones, not coming from an app, so I don't see a way to control those in that setting.
Oh well.
adavid7
by adavid7 on Mon Mar 01, 2021 9:08 pm
I did find a partial workaround for this problem. If you select the Do Not Disturb control, then you can turn notifications off for just an hour, for example. SO if you know you are going to be doing a bunch of coding, you could do this and suppress the notifications while you are working in MakeCode.
adavid7
by mikeysklar on Tue Mar 02, 2021 4:31 pm
Thank you for sharing this. Shutting off notifications even if only for an hour can at least make using this tolerable under BigSur.
mikeysklar
