Arduino Nano + Adafruit Music Maker FeatherWing
Play with it! Please tell us which board you're using.
IoT_hobbyist
Post by IoT_hobbyist »
Hello Everyone,
I am using Adafruit Music Maker FeatherWing with Arduino Nano. I did wiring as below
I run the example code from Adafruit_VS1053 but it does not work. I simplify the code as bellow:
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
//#define CLK 13       // SPI Clock, shared with SD card
//#define MISO 12      // Input data, from VS1053/SD card
//#define MOSI 11      // Output data, to VS1053/SD card
// Connect CLK, MISO and MOSI to hardware SPI pins.
// See http://arduino.cc/en/Reference/SPI "Connections"
#define BREAKOUT_RESET  9      // VS1053 reset pin (output)
#define BREAKOUT_CS     10     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    8      // VS1053 Data/command select pin (output)
#define CARDCS 4     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  Serial.begin(9600);
  Serial.println("Adafruit VS1053 Simple Test");
  if (! musicPlayer.begin()) { // initialise the music player
     Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
     while (1);
  Serial.println(F("VS1053 found"));
   if (!SD.begin(CARDCS)) {
    Serial.println(F("SD failed, or not present"));
    while (1);  // don't do anything more
  // list files
  printDirectory(SD.open("/"), 0);
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(20,20);
  // Timer interrupts are not suggested, better to use DREQ interrupt!
  //musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT); // timer int
  // If DREQ is on an interrupt pin (on uno, #2 or #3) we can do background
  // audio playing
  musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);  // DREQ int
  // Play one file, don't return until complete
  Serial.println(F("Playing track 001"));
  musicPlayer.playFullFile("/track001.mp3");
  // Play another file in the background, REQUIRES interrupts!
  Serial.println(F("Playing track 002"));
  musicPlayer.startPlayingFile("/track002.mp3");
  // File is playing in the background
  if (musicPlayer.stopped()) {
    Serial.println("Done playing music");
    while (1) {
      delay(10);  // we're done! do nothing...
  delay(100);
/// File listing helper
void printDirectory(File dir, int numTabs) {
   while(true) {
     File entry =  dir.openNextFile();
     if (! entry) {
       // no more files
       //Serial.println("**nomorefiles**");
       break;
     for (uint8_t i=0; i<numTabs; i++) {
       Serial.print('\t');
     Serial.print(entry.name());
     if (entry.isDirectory()) {
       Serial.println("/");
       printDirectory(entry, numTabs+1);
     } else {
       // files have sizes, directories do not
       Serial.print("\t\t");
       Serial.println(entry.size(), DEC);
     entry.close();
The output in Serial Monitor:
However, there is no sound on speaker.
I have tested the speaker separately. There is no problem with speaker.
Could anyone please point out any my mistake?
mikeysklar
Re: Arduino Nano + Adafruit Music Maker FeatherWing
Post by mikeysklar »
Let's see some photos of your setup with the wiring and how the speaker is connected.
It's a good sign that you appear to have serial output and your code is running.
Do you need to define custom pins for the Nano?
Have you tried the feather_player example?
https://learn.adafruit.com/adafruit-mus ... play-music
IoT_hobbyist
Firstly,
I do not define any custom pin.
All are default. It is shown on code and wiring diagram I posted.
Secondly, The link you provide redirect to the main page. There is no content for playing soud
mikeysklar
You need to do two things:
1) Follow the link I sent and read the contents as you are using a Feather Player and the pinout configurations are different based on the controller you choose.
2) You need to start with the feather_player example included in the VS1053 library.
// Specifically for use with the Adafruit Feather, the pins are pre-set here!
#include <SPI.h>
#include <SD.h>
// These are the pins used
#define VS1053_RESET   -1     // VS1053 reset pin (not used!)
// Feather ESP8266
#if defined(ESP8266)
  #define VS1053_CS      16     // VS1053 chip select pin (output)
  #define VS1053_DCS     15     // VS1053 Data/command select pin (output)
  #define CARDCS          2     // Card chip select pin
  #define VS1053_DREQ     0     // VS1053 Data request, ideally an Interrupt pin
// Feather ESP32
#elif defined(ESP32)
  #define VS1053_CS      32     // VS1053 chip select pin (output)
  #define VS1053_DCS     33     // VS1053 Data/command select pin (output)
  #define CARDCS         14     // Card chip select pin
  #define VS1053_DREQ    15     // VS1053 Data request, ideally an Interrupt pin
// Feather Teensy3
#elif defined(TEENSYDUINO)
  #define VS1053_CS       3     // VS1053 chip select pin (output)
  #define VS1053_DCS     10     // VS1053 Data/command select pin (output)
  #define CARDCS          8     // Card chip select pin
  #define VS1053_DREQ     4     // VS1053 Data request, ideally an Interrupt pin
// WICED feather
#elif defined(ARDUINO_STM32_FEATHER)
  #define VS1053_CS       PC7     // VS1053 chip select pin (output)
  #define VS1053_DCS      PB4     // VS1053 Data/command select pin (output)
  #define CARDCS          PC5     // Card chip select pin
  #define VS1053_DREQ     PA15    // VS1053 Data request, ideally an Interrupt pin
#elif defined(ARDUINO_NRF52832_FEATHER )
  #define VS1053_CS       30     // VS1053 chip select pin (output)
  #define VS1053_DCS      11     // VS1053 Data/command select pin (output)
  #define CARDCS          27     // Card chip select pin
  #define VS1053_DREQ     31     // VS1053 Data request, ideally an Interrupt pin
// Feather M4, M0, 328, nRF52840 or 32u4
#else
  #define VS1053_CS       6     // VS1053 chip select pin (output)
  #define CARDCS          5     // Card chip select pin
  // DREQ should be an Int pin *if possible* (not possible on 32u4)
  #define VS1053_DREQ     9     // VS1053 Data request, ideally an Interrupt pin
#endif
  Adafruit_VS1053_FilePlayer(VS1053_RESET, VS1053_CS, VS1053_DCS, VS1053_DREQ, CARDCS);
  Serial.begin(115200);
  // if you're using Bluefruit or LoRa/RFM Feather, disable the radio module
  //pinMode(8, INPUT_PULLUP);
  // Wait for serial port to be opened, remove this line for 'standalone' operation
  while (!Serial) { delay(1); }
  delay(500);
  Serial.println("\n\nAdafruit VS1053 Feather Test");
     while (1);
  musicPlayer.sineTest(0x44, 500);    // Make a tone to indicate VS1053 is working
  Serial.println("SD OK!");
  // list files
  musicPlayer.setVolume(10,10);
#if defined(__AVR_ATmega32U4__)
  // but we don't have them on the 32u4 feather...
#else
  // If DREQ is on an interrupt pin we can do background
  // audio playing
#endif
  // Play a file in the background, REQUIRES interrupts!
  Serial.println(F("Playing full track 001"));
  Serial.print(".");
    while (1) {
  if (Serial.available()) {
    char c = Serial.read();
    // if we get an 's' on the serial console, stop!
    if (c == 's') {
      musicPlayer.stopPlaying();
    // if we get an 'p' on the serial console, pause/unpause!
    if (c == 'p') {
      if (! musicPlayer.paused()) {
        Serial.println("Paused");
        musicPlayer.pausePlaying(true);
      } else {
        Serial.println("Resumed");
        musicPlayer.pausePlaying(false);
  delay(100);
   while(true) {
     if (! entry) {
       // no more files
       break;
       Serial.print('\t');
     } else {
     entry.close();
IoT_hobbyist
Dear mikeysklar.
Thank you for your comment.
I did that at the beginning for Arduino Nano, as shown on the wiring diagram and code.
Is there any other possible reasons?
Did Adafruit tested it with an Arduino such as Uno ?
mikeysklar
We have an Arduino UNO shield based "Music Maker" so this FeatherWing was probably never tested with non Feather family products.
https://www.adafruit.com/product/1790
That being said you can make some comparisons of pins used between the Shield and Feather Music Maker versions and see if that provides any clues.
https://learn.adafruit.com/adafruit-mus ... er/pinouts
How did it go with the Feather code and your custom pinouts? I didn't see your output from running that on the console.
IoT_hobbyist
Dear Adafruit's supporter,
Did you read my original post?
I posted it clearly at the beginning with code, wiring diagram and output on Serial Monitor.
I am sorry If I misunderstood something.
rafikii
Post by rafikii »
Did you figure it out? I can play a tone and read from the SD card, but like you I cannot play an audio file.
I tried the hardware and software SPI versions of the musicplayer constructor from the Library Reference page of the Music Maker guide.
IoT_hobbyist
rafikii wrote:Did you figure it out? I can play a tone and read from the SD card, but like you I cannot play an audio file.
No, I did not. Please read this https://www.trustpilot.com/review/www.adafruit.com before posting question on Adafruit
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
