final format for E-Ink Python
by scotch1 on Sat Feb 27, 2021 2:36 am
Can anyone help with final formatting of a time delta result to only minutes as a number for a countdown:
equation is:
differential = next_class_start - time_now
Call of:
print(*differential)
Result:
0 days 00:04:32.133860
Seeking to have ONLY minutes, convertible to a number for operations, conditional statements
Reference isn't clear enough: https://pandas.pydata.org/pandas-docs/stable/reference/api/pandas.Timedelta.html
Used without the *:
print(differential)
Results in:
66   00:00:21.336076
Name: START, dtype: timedelta64[ns]
scotch1
Re: final format for E-Ink Python
by millercommamatt on Mon Mar 01, 2021 3:18 pm
timedeltas are stored as days, seconds, and microseconds https://docs.python.org/3/library/datetime.html#timedelta-objects
If you want only minutes you could do this:
import datetime as dt
test_diff = dt.timedelta(days=2, hours=3, seconds=4.5)
mins = (test_diff.days*60*60*24 + test_diff.seconds)/60  # ignoring the microseconds
print(mins)
print('{:.2f} minutes elapsed'.format(mins))
round or floor or string format as you would like to present the minutes the way you want
millercommamatt
by scotch1 on Tue Mar 02, 2021 2:45 am
OK, might have lucked out in approach of attached code, which effectively works on laptop, then breaks in PI/E-ink and I can't understand it.... see how the conditional statement works when minutes to next class are within the target, then, somehow, when it goes to zero, totally goes blank for the first minute...... Laptop python prep below and attached, PI in next post... Really would appreciate help to finish before my kids go back to school in 2 weeks ;( (plus, intend on conditional statement is to sound a buzzer when minutes_next gets to 1 min, think I have that sorted, if I can get the code to work in PI/e-ink......
Code in Python on Laptop:
A_WIP_006.py
(3.11 KiB) Downloaded 4 times
references this file:
class_shedule_2.csv
(1.71 KiB) Downloaded 2 times
image:
Result:
Info:
22:22 PM
Mon
Monday
Schoolday
load school schedule
Into Bed, Story time
Next Event is: Dream Land
Next event is a class, starting at:  22:26PM
219.83
[b]3.66[/b]
Class Starting in: [b]3.66[/b] minutes
Gets to less than 0 min and goes blank:
Info:
22:26 PM
Mon
Monday
Schoolday
Next Event is:
Not a next class
then after the minute is passed, starts reading the info again:
Info:
22:28 PM
Mon
Monday
Schoolday
Dream Land
Next Event is: Sleeping Right
Not a next class
Now SAME code in Raspberry Pi and the Pimorini inky pHAT:
Error: Next post.....
scotch1
by scotch1 on Tue Mar 02, 2021 2:56 am
This is the pi to inky/phat code which seems to:
1) work when next_class_status = 'No', displays "N/a"s
2) breaks at lines 81 when 'Yes'
NOte, I had to change lines 131 and 134 to str(*message.EVENT) and str(*message_ahead) to work but then it breaks.
skool_3_WIP.py
(4.73 KiB) Downloaded 2 times
Easiest way to test it is to open the csv file, change start of next class and add a "Yes" if not obvious.
Any way to get it running would be extremely appreciated :)
scotch1
by millercommamatt on Tue Mar 02, 2021 10:24 am
A few things I see from a cursory glance at your code:
Redundant import statements:
import datetime
from datetime import timedelta
if you want to keep commands smaller try:
from datetime import datetime
Now you can use datetime instead of datetime.datetime
Doublecheck your datatypes.
The error on line 81 in complaining that one variable is a string and one is a datetime. Both need to be types supported by datetime.
Keep experimenting. If I have time later, I'll take a deeper look and try to piece together what you're doing and where things are going awry.
millercommamatt
by millercommamatt on Tue Mar 02, 2021 1:23 pm
You're getting a blank because your time_now_str is greater or equal to the end or less than or equal to the next start.
Use >= and <= instead of > and <. Or, adjust your Start and End time to not have a gap at minute resolution.
millercommamatt
by scotch1 on Wed Mar 03, 2021 3:29 am
Appreciate the insight: See the bracket issue and complication on seeing two values.
Believe the >= solved the laptop version.
The PI version still having an issue with the line 81 equation which works on laptop, wondering if it was teh default "n/a" values as strings or str in the eink display sections, shown here:
1:
2:
3:
scotch1
by scotch1 on Wed Mar 03, 2021 3:36 am
...Also, I decided to buy an M4 + ThinkInk 2.9" + realtime clock to get around the slowness of the Pimorini EInk refresh (15 sec) and slow debugging thru VNC thinking that circuit python on the M4 would be the answer to more reliable python usage: However as seen in this post https://forums.adafruit.com/viewtopic.php?f=60&t=176221, it appears that the M4 can't read csv or use pandas. Had the script set up using about 200 lines of conditional statements for day and time, then friend suggested using pandas to read the timetable which pushed my coding to get to this point and get the values, but see that it'll be no use to the M4?
Do you think M4 can work with this python code set up for pi? Can the Think Ink 2.9" feather be used with the PI if I have to sub off and hardwire the pi to it?
scotch1
by scotch1 on Fri Mar 05, 2021 4:16 am
Found it: Seems the variable was being defined as a N/A string and caused the issue!
THat plus some last item strftime, and it goes!
Whoo!
scotch1
by millercommamatt on Fri Mar 05, 2021 10:27 am
huzzah!
millercommamatt
