CPX and Wifi or BLE
Re: CPX and Wifi or BLE
by l8throp on Thu Mar 18, 2021 12:52 am
The CircuitPython building for the CPX does not list "_bleio" as a built-in module (which is used by the adafruit_ble library) on the CircuitPython page for this board: https://circuitpython.org/board/circuit ... d_express/ (Compared to, as an example, the ItsyBitsy M4, which does list it)
As such, it seems like you'll likely need to build a custom build of CircuitPython, but I'm not sure if the SAMD21 on the CPX will be good at support it as other SAMD21 boards also lack it.
l8throp
by lamachine on Fri Mar 19, 2021 6:54 pm
Same error here. When I run help("modules") the _bleio shows up in a feather nRF52840 but NOT in the Circuit Playground Express.
lamachine
by mikeysklar on Mon Mar 22, 2021 5:35 pm
Looking at the docs for adafruit_ble you might be out of luck. I know this library is looking for native BLE hardware on startup. There is an argument for a device to be specificed when initializing BLERadio(), but it still might not work on the SAMD21 hw.
https://github.com/adafruit/Adafruit_Ci ... __.py#L141
class BLERadio:
    BLERadio provides the interfaces for BLE advertising,
    scanning for advertisements, and connecting to peers. There may be
    multiple connections active at once.
    It uses this library's `Advertisement` classes and the `BLEConnection` class."""
    def __init__(self, adapter=None):
        """If no adapter is supplied, use the built-in `_bleio.adapter`.
        If no built-in adapter is available, raise `RuntimeError`.
        if adapter is None and _bleio.adapter is None:
            raise RuntimeError("No adapter available")
        self._adapter = adapter or _bleio.adapter
        self._current_advertisement = None
        self._connection_cache = {}
The more elegant option would be of course to use the Bluefruit CPX.
https://www.adafruit.com/product/4333
mikeysklar
