PyPortal doesn't boot
by shipstone on Mon Mar 01, 2021 3:57 pm
Hi, first time here! Purchased and plugged the PyPort (Adafruit PyPortal Pynt - CircuitPython Powered Internet Display - 2.4" TFT PID: 4465) into my chromebook. Initially, it appeared to work, showing a green light and the PyPortal screen. However, I was never able to get the usb drive to show up on my chromebook. I used the reset button several times (twice rapidly, button down on power up) and it made no difference. I tested with multiple cables without any improvement. At some point in the process the reset to the PyPort screen stopped working, and instead, I got one steady red and one flickering red on the board and nothing on the screen (see attached images).
I then moved to a Windows laptop and the behavior is the same. Suggestions appreciated!
pyportal board with red leds
pyportal screen not active
PXL_20210301_180352134 (1).jpg (280.33 KiB) Viewed 75 times
shipstone
Re: PyPortal doesn't boot
by adafruit_support_carter on Mon Mar 01, 2021 4:41 pm
Try different USB cables. Make sure it is not a charge only cable. Then keep trying the double-press of reset to get into bootloader mode. The red LEDs in the photo are an indication that the board can not see your PC's USB port.
by shipstone on Mon Mar 01, 2021 8:25 pm
Finally got a cable that worked. Thank you, working now.
shipstone
by adafruit_support_carter on Mon Mar 01, 2021 8:30 pm
Cool, glad it was something simple. Thanks for letting us know.
