Not Working
Not Working
by GiRafn1 on Mon Mar 08, 2021 9:34 am
Hi
It is my first time playing with the circuit playground express, but I can't get it to work.
I have tried to plug it into my computer and press the reset button as the tutorial says, but nothing happens, there is no light or anything. Is there anything I have overlooked or something I have to do to make it work? (I have checked the usb-cable and it's working like it should)
Regards
Julie
GiRafn1
Re: Not Working
by adafruit_support_carter on Mon Mar 08, 2021 2:54 pm
Hello! First, let's make sure which Circuit Playground you have, since they sometimes get confused.
The Express is PID 3333, this one:
https://www.adafruit.com/product/3333
Is that what you have, or did you end up with the PID 3000, i.e. the Classic:
https://www.adafruit.com/product/3000
How to tell:
https://learn.adafruit.com/introducing- ... vs-express
Re: Not Working
by GiRafn1 on Mon Mar 08, 2021 7:18 pm
Hi
It is the Express circuit I got
GiRafn1
Re: Not Working
by adafruit_support_carter on Mon Mar 08, 2021 7:25 pm
OK, thanks for confirming. Try double pressing the reset button. Do you get any LEDs then?
Is the little green LED next to the USB connector also not coming on?
Re: Not Working
by GiRafn1 on Tue Mar 09, 2021 5:43 am
I just tried double pressing the reset button, but it is stil not working.
as soon as I plug in the micro b the green LED will blink one time and then die down
GiRafn1
Re: Not Working
by adafruit_support_carter on Tue Mar 09, 2021 11:13 am
That behavior with the green LED is odd. That's the power indicator LED and should just stay on.
How did you verify the USB cable works? If you can, try with some other USB cables and see if you get the same behavior with the green LED.
Is this a new Circuit Playground board? Or has it been used before?
Re: Not Working
by GiRafn1 on Wed Mar 10, 2021 3:57 am
I tried the usb cable with my powerbank and it worked. I just tried with all my usb cables and it has the same reaction as the first.
It should be a new circuit, I haven't used it before
GiRafn1
Re: Not Working
by adafruit_support_carter on Wed Mar 10, 2021 12:33 pm
OK, and just to be sure here - that's the green LED coming on briefly and then going out?
Re: Not Working
by GiRafn1 on Thu Mar 11, 2021 4:12 am
Yes that is correct
GiRafn1
Re: Not Working
by adafruit_support_carter on Thu Mar 11, 2021 10:39 am
Let's try a replacement. Not sure what is causing that behavior, but that LED should not need anything more than just power to stay on.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement Circuit Playground.
Re: Not Working
by allenq on Fri Mar 12, 2021 5:07 pm
I have a very similar problem with a new Circuit Playground - Bluetooth Low Energy. The only difference is that all of the LEDs flash briefly red and the power LED flashes briefly green (at the same time as the red flash), then they all go off. When I plug it in again, the same thing happens, It also makes a tiny chirp.
allenq
Re: Not Working
by adafruit_support_carter on Mon Mar 15, 2021 2:33 pm
@allenq Please start a new thread for your issue.
cron
