Debugging MatrixPortal Issue
by sayvazov on Tue Apr 06, 2021 5:09 pm
Hi all,
I'm working with a MatrixPortal I got through one of the Adaboxes a little while ago and am at a loss as to what's going on here. I'm really just working with pretty simple behavior: I'm connecting to an Adafruit IO feed and displaying the data on an led matrix. My issue is: the MatrixPortal will work just fine for many hours at a time and at some point randomly starts error looping on a "RuntimeError: ESP32 timed out on SPI select."
I found a thread here and have gone through updating both the board and AirLift firmware, but still see it pop up. Any ideas as to what might be happening?
As a side question: is there a CircuitPython command to reset the board? Or even to reset the network connection? An error loop would be a lot less annoying to deal with if I could gracefully recover. As it is, I have to manually hit the reset button.
sayvazov
Re: Debugging MatrixPortal Issue
by adafruit_support_carter on Tue Apr 06, 2021 5:31 pm
Sounds like something intermittent. So it might be network related. Or even AIO related if you are hitting an upload rate limit to your account. Would it work for your case to use a try/except to catch the error and retry?
You can hard reset with microcontroller.reset():
https://circuitpython.readthedocs.io/en ... ller.reset
and can soft reset with supervisor.reload():
https://circuitpython.readthedocs.io/en ... sor.reload
by sayvazov on Tue Apr 06, 2021 6:18 pm
adafruit_support_carter wrote:Sounds like something intermittent. So it might be network related. Or even AIO related if you are hitting an upload rate limit to your account. Would it work for your case to use a try/except to catch the error and retry?
That's what I'm currently doing. Once it gets one of these SPI errors, it never succeeds again. As in, it works for 8 hours doing the try/except loop and then doesn't work ever again.
I'll try the reset code, thanks!
sayvazov
by adafruit_support_carter on Wed Apr 07, 2021 2:12 pm
FWIW, we just added a new Learn Guide page on resetting:
https://learn.adafruit.com/circuitpytho ... -resetting
by sayvazov on Thu May 13, 2021 5:06 pm
Hi, reviving this thread. I've been trying to to work on this for a little while now, but it seems using the reset code has revealed another issue. My MatrixPortal will sometimes just... hang. I thought at first it was a code issue, or a problem with the way I'm handling the reset, but it seems to just get stuck - when connected to my computer, it disappears as a drive as well. If I run a simple script that doesn't touch networking, this doesn't seem to happen. Digging around, I thought I had seen github issues of a similar nature, but I can't seem to find them now. Any ideas? It's also very possible I damaged the matrixportal at some point in the last 6 months and I should just get a new one, but thought I'd post again first.
sayvazov
by adafruit_support_carter on Mon May 17, 2021 11:11 am
What if you completely remove code.py so there's nothing that gets run automatically. Can you get to the serial REPL OK?
