Piezoelectric knock sensor
by Walter_doesnt_know on Thu Apr 08, 2021 11:41 pm
I want to use a this piezoelectric element ( https://www.adafruit.com/product/1739 ) as a knock sensor with a Circuitplayground express, but I am having trouble finding anything on the subject. I need to know how to hook it up and how to code it (so sorry for my complete noobness). Ultimately, my goal is to have the CPX change the text displayed on a TFT gizmo. I already have the TFT gizmo text working pretty well. Thanks for anything you can do!
Walter_doesnt_know
Re: Piezoelectric knock sensor
by mikeysklar on Fri Apr 09, 2021 5:58 pm
You have the hardware built into the CPX for easy "tap" detection (accelerometer) if you wanted to start with a trivial example and build up from there.
# Circuit Playground Express Tap Detect
# Author: Carter Nelson
# MIT License (https://opensource.org/licenses/MIT)
from adafruit_circuitplayground.express import cpx
# Configure double tap detection
cpx.detect_taps = 2
# Loop forever
while True:
    if cpx.tapped:
        print("TAP!")
https://learn.adafruit.com/circuit-play ... p-detect-2
We do have an older guide on knock detection using a piezo buzzer which is more involved, but you could take a look at the schematic to get an idea of what is going on there.
https://learn.adafruit.com/secret-knock ... ock/wiring
mikeysklar
