MakeCode CPX Sound Sensor Trigger Issue
by KathyCeceri on Mon Apr 26, 2021 1:20 pm
When I write a MakeCode program with an "on loud sound" trigger, it always seems to run when I turn the CPX board on. I tried adding a pause in an "on start" block in case the noise of switching it on was the problem, but that has not solved it. Any ideas? Please note that I am writing demonstration programs for beginners (8-11 yo and 12-16 yo), so if it's a complicated coding fix, I'll just leave it be.
Also, I have no updated the firmware on my CPX boards in more than a year, could that be an issue? Thanks!
KathyCeceri
Re: MakeCode CPX Sound Sensor Trigger Issue
by mikeysklar on Wed Apr 28, 2021 3:05 pm
Along the same lines as you "pause" upon startup would it make sense to not let the code start running until button A has been pressed?
"on button A pressed"
mikeysklar
by KathyCeceri on Thu Apr 29, 2021 4:07 pm
mikeysklar wrote:Along the same lines as you "pause" upon startup would it make sense to not let the code start running until button A has been pressed?
I was thinking of something similar, using the left/right switch. The problem is that you can't nest the "on loud sound" block inside another block. I will be teaching them how to build their own using If/Then/Else, but for a first project, it's too complicated.
KathyCeceri
