CIRCUIT PLAYGROUND ERROR LIGHTS
by steamtruck on Tue Apr 27, 2021 10:57 am
The CPX produced these error lights (and movement stopped) after our robot had traveled around for a few minutes. Could someone clarify what the lights indicate?
steamtruck
Re: CIRCUIT PLAYGROUND ERROR LIGHTS
by adafruit_support_carter on Tue Apr 27, 2021 12:14 pm
What code were you running on the CPX?
by steamtruck on Tue Apr 27, 2021 2:13 pm
Here are screenshots from my colleague:
Screen Shot 2021-04-27 at 12.39.29 PM.png (80.28 KiB) Viewed 349 times
Screen Shot 2021-04-27 at 12.39.39 PM.png (53.66 KiB) Viewed 349 times
steamtruck
by Paco_Hanlon on Wed Apr 28, 2021 8:43 am
Hello. I have a video attached here of this problem. It works to run the continuous servos on first push of the button, but the second one causes the error.
https://drive.google.com/file/d/1ocWKIIJ5M1v6nlLwrN_HZzCwljgCe0iQ/view?usp=sharing
If I'm reading the lights correctly, it looks like the error code is 0101101000, which is 90, and corresponds to "90 (PANIC_CODAL_HARDWARE_CONFIGURATION_ERROR): actual board hardware doesn’t match the configuration description"
Paco (via STEAM Truck)
Paco_Hanlon
by adafruit_support_carter on Wed Apr 28, 2021 9:43 am
You could be dealing with a brown out issue (power related) since you are using batteries to drive servos. Does the CPX behave OK if you revert back to testing with some non-servo code? Can be anything, like maybe something that just spins the NeoPixels.
by Paco_Hanlon on Wed Apr 28, 2021 11:26 am
We figured it out. Apparently when you use the STOP SERVO command, it renders that servo unusable, so the next time a command is sent, it has the hardware error.
That begs the question, of course, how can we stop a servo motor without a stop command? We found a workaround by programming the servos to continuously move at 0% (this didn't QUITE work, because of the inaccuracy of inexpensive servos, but if you do -3% they generally stop).
Does MakeCode and Adafruit know that the Stop Servo command doesnt work as intended? (unless that IS how it was intended)
Paco_Hanlon
by adafruit2 on Sat May 01, 2021 8:15 pm
yah 'stop servo' disconnects the servo completely.
to stop the servo from turning you would set it to 0% there's a little screw in the body of the servo, you can tweak it until 0% is 'off'
https://learn.sparkfun.com/tutorials/co ... rvo-motors
adafruit2
Site Admin
