Circuit Playground Classic and SloftwareSerial
by fredless on Wed Apr 28, 2021 4:01 pm
I'm struggling to get an XBee module working properly with a Circuit Playground Classic. If I use generic Arduino code, it works fine. If I use a standard CP function like CircuitPlayground.lightSensor() it also works.
But if I run CircuitPlayground.begin() to reset the Circuit Playground, the XBee via SoftwareSerial no longer transmits. I've tried it both before and after the serial.begin functions. Any ideas?
thanks.
working code:
#include <Adafruit_CircuitPlayground.h>
#include<SoftwareSerial.h> // header file of software serial port
SoftwareSerial mySerial(9, 10); // define software serial port name as mySerial and pin 9 as RX and pin 10 as TX
int lightSensorPin = A5; // Circuit Playground light sensor is Analog Pin A5
int value;
//CircuitPlayground.begin(); // does not work with SoftwareSerial!
Serial.begin(9600);
mySerial.begin(9600);
//value = CircuitPlayground.lightSensor(); // this works even without CircuitPlayground.begin()
value = analogRead(lightSensorPin);
Serial.print("Light Sensor: ");
Serial.println(value);
mySerial.write(value);
delay(100);
fredless
Re: Circuit Playground Classic and SloftwareSerial
by mikeysklar on Fri Apr 30, 2021 3:18 pm
I've seen this conflict happen before with the CircuitPlayground.begin() knocking out software serial. Do you really need the CircuitPlayground functions in this case? I suppose the alternative would be to use a different device like the Circuit Playground Express which has two hardware serial ports. I do not have a good suggestions for using both the CircuitPlayground built-ins and software serial simultaniously on the CircuitPlayground Classic.
mikeysklar
