Button in use in a Py program, not live
Play with it! Please tell us which board you're using.
HoustonGeek
Post by HoustonGeek »
CPE - 3.13.0 BL, CPE Code 3.6.0
My code.py:
2 import board
3 import digitalio
4 from adafruit_circuitplayground.express import cpx
5 #comment
6 button_a = digitalio.DigitalInOut(board.BUTTON_A)
7 button_a.direction = digitalio.Direction.INPUT
8 button_a.pull = digitalio.Pull.DOWN
and get a
code.py ouput:
  File "code.py", line 6, in <module>
ValueError: BUTTON_A in use
however, when I issue those commands in the interpreter, it runs fine.
Reflash the CPE code? Not sure what the issue is
adafruit_support_carter
Re: Button in use in a Py program, not live
It should do the same thing either way. The CPX library sets up the digital input for you. So when you import it here:
BUTTON_A gets used. Here's the actual code that does that from the CPX library:
https://github.com/adafruit/Adafruit_Ci ... ase.py#L61
So you don't need to do any of this:
Instead, access the button via the imported cpx object. Ex:
https://github.com/adafruit/Adafruit_Ci ... utton_a.py
HoustonGeek
Got it - I see newer projects with the correct code. Might want to think about deprecating the old posts.
Please link to this and we'll take a look.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
