Is there a switch-case syntax in CircuitPython?
by chipnod2020 on Fri Jun 04, 2021 11:44 am
I am translating a script I have that is written in C++ to CircuitPython - Raspberry Pi Pico. One place I'm getting stuck with is the current switch-case setup I have.
Is there a CircuitPython equivalent?
#include <ezButton.h>
#include <Adafruit_DotStar.h>
#include <SPI.h>         // COMMENT OUT THIS LINE FOR GEMMA OR TRINKET
//#include <avr/power.h> // ENABLE THIS LINE FOR GEMMA OR TRINKET
#define EFFECT_STATE_NONE 0
#define EFFECT_STATE_MOVE 1
#define EFFECT_STATE_FADE 2
#define NUMPIXELS 30 // Number of LEDs in strip
// Hardware SPI is a little faster, but must be wired to specific pins
// (Arduino Uno = pin 11 for data, 13 for clock, other boards are different).
Adafruit_DotStar strip(NUMPIXELS, DOTSTAR_BRG);
ezButton button(7);  // create ezButton object that attach to pin 7;
unsigned long EFFECT_TIME_ALL  = 5000;// Length of the entire process
unsigned long EFFECT_TIME_FADE = 1000;// How long do you want them to flicker when they meet in the middle
unsigned long EFFECT_TIME_MOVE = EFFECT_TIME_ALL - EFFECT_TIME_FADE;
int EFFECT_FADE_NUM = 4; // fade 4 time between 200 and 255, you can change this value
int    lengthA = NUMPIXELS;
int      headX = 0;
int      headY = NUMPIXELS;
int    randomN = 0;
uint32_t color = 0xFFA500;
unsigned long timeMoveStart;
unsigned long timeFadeStart;
unsigned long progress;
unsigned long brightness = 0;
int fadeCount = 0;
int effectState = EFFECT_STATE_NONE;
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000L)
  clock_prescale_set(clock_div_1); // Enable 16 MHz on Trinket
#endif
  strip.begin(); // Initialize pins for output
  strip.show();  // Turn all LEDs off ASAP
  button.setDebounceTime(50); // set debounce time to 50 milliseconds
  button.loop(); // MUST call the loop() function first
  switch (effectState) {
    case EFFECT_STATE_NONE:
      if (button.isPressed()) {
        effectState = EFFECT_STATE_MOVE;
        timeMoveStart = millis();
        randomN = random(0, lengthA); // The min is 0 and max is lengthA - 1
      break;
    case EFFECT_STATE_MOVE:
      progress = millis() - timeMoveStart;
      brightness = map(progress, 0, EFFECT_TIME_MOVE, 0, 200);
      headX = map(progress, 0, EFFECT_TIME_MOVE, 0, randomN);
      headY = map(progress, 0, EFFECT_TIME_MOVE, lengthA, randomN);
      if (headX >= randomN) {
        headX = randomN;
        headY = randomN;
        effectState = EFFECT_STATE_FADE;
        timeFadeStart = millis();
        fadeCount = 0;
      break;
    case EFFECT_STATE_FADE:
      progress = millis() - timeFadeStart;
      if ((fadeCount % 2) == 0) { // fade up
        brightness = map(progress, 0, EFFECT_TIME_FADE / EFFECT_FADE_NUM, 200, 255);
        if (brightness > 255) {
          fadeCount++;
      } else {// fade down
        brightness = map(progress, 0, EFFECT_TIME_FADE / EFFECT_FADE_NUM, 255, 200);
        if (brightness < 200) {
          fadeCount++;
      if (fadeCount > EFFECT_FADE_NUM) {
        brightness  = 0; // turn off all
      break;
  strip.setBrightness(brightness);
  for (int i = 0; i <= lengthA; i++) {
    if (i == headX || i == headY)
      strip.setPixelColor(i, color);
    else
      strip.setPixelColor(i, 0); // turn off
  strip.show();
chipnod2020
Re: Is there a switch-case syntax in CircuitPython?
by dastels on Fri Jun 04, 2021 3:05 pm
No. You would use somethign like:
if effectState == EFFECT_STATE_NONE:
elif effectState == EFFECT_STATE_MOVE:
and so on.
If there's any complexity to the structure, I usually switch to a polymorphic subclass-per-state approach. See https://learn.adafruit.com/circuitpython-101-state-machines.
dastels
by chipnod2020 on Fri Jun 04, 2021 4:54 pm
Thanks dastels!
Is it correct that there isn't a map function in CP?
chipnod2020
by dastels on Fri Jun 04, 2021 8:19 pm
There's map. See https://learn.adafruit.com/circuitpython-101-list-and-things-iterators-generators. A list comprehension is the more idiomatic way to do it, though. E.g.
>>> a = range(20)
>>> list(map(lambda x: x**2, a))
[0, 1, 4, 9, 16, 25, 36, 49, 64, 81, 100, 121, 144, 169, 196, 225, 256, 289, 324
, 361]
>>> [x**2 for x in a]
, 361]
dastels
