temp readings
Play with it! Please tell us which board you're using.
Picaboo
temp readings
Post by Picaboo »
I am new to the device and setting up the data logger for time and temperature. Why are my temp readings 528 if I have it set for temp in degrees celsius? I am at room temperature.
Re: temp readings
What temperature sensor are you using? And what processor? Please post photos showing all of your soldering and connections.
Picaboo
Re: temp readings
Post by Picaboo »
I am using the temp sensor that is part of the CPX itself. Not an attached sensor.
M
Re: temp readings
[Moved topic to the Circuit Playground forum]
Please post the code you are using.
Picaboo
Re: temp readings
Post by Picaboo »
Screen Shot 2021-07-08 at 11.11.31 AM.png (117.53 KiB) Viewed 3118 times
I tried both of these and had the same issue.
Screen Shot 2021-07-08 at 11.11.42 AM.png (132.85 KiB) Viewed 3118 times
johnpark
Re: temp readings
Post by johnpark »
You may need to include a pause after each line is written to the datalogger. Do you get proper values if you run the program shown in this guide? https://learn.adafruit.com/data-logging ... logger-use
Picaboo
Re: temp readings
Post by Picaboo »
Screen Shot 2021-07-12 at 9.57.39 AM.png (166.6 KiB) Viewed 2888 times
Screen Shot 2021-07-12 at 10.00.16 AM.png (73.17 KiB) Viewed 2888 times
Thanks. I am getting real readings now. Some more questions:
1. Is there any way to get a new log.csv file so that it doesn't just keep adding to the same one?
2. Can you explain what this does? See attached orange block.
3. Finally, why didn't this code give me any data? See attached.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
