NEOPIXEL MATRIX NOT RESPONSIVE PYTHON FT232H
Play with it! Please tell us which board you're using.
apaul
Post by apaul »
I'm trying to control LEDs on a matrix ( https://www.adafruit.com/product/2294 , WS2812B based) using a FT232H ( https://www.adafruit.com/product/2264 ).
Although the code runs without any exception no LEDs are turned on. I've tried multiple matrices and FT232H, it seems not to be a hardware failure. Furthermore it is definitely soldered correctly and if I connect a simple LED strip it's working.
Setup:
Relevant python packages:
  • Adafruit-Blinka 6.12.0
    adafruit-circuitpython-busdevice 5.0.6
    adafruit-circuitpython-neopixel-spi 0.9.1
    adafruit-circuitpython-pypixelbuf 2.2.6
    Adafruit-PlatformDetect 3.15.3
    Adafruit-PureIO 1.1.9
    pyftdi 0.53.1
Python code:
import board  # type: ignore
import neopixel_spi as neopixel  # type: ignore
NUM_PIXELS = 5
PIXEL_ORDER = neopixel.GRB
spi = board.SPI()
pixels = neopixel.NeoPixel_SPI(
        spi,
        n=NUM_PIXELS,
        brightness=0.05,
        pixel_order=PIXEL_ORDER,
pixels.fill(0xFFFFFF)
# Doing some stuff...
pixels.fill(0x000000)
I'd appreciate any help!
mikeysklar
Re: NEOPIXEL MATRIX NOT RESPONSIVE PYTHON FT232H
Post by mikeysklar »
It looks like the example code has some issues.
Your using an RGB matrix, but it is being initialized with a GRB and only five pixels. Both of which you want to change. The last line of the code is also turning all the pixels off so you should not expect to see anything without any pause or loop.
It would probably make more sense to start with a matrix demo code and make the necessary modifications to work with the FT232H.
https://learn.adafruit.com/easy-neopixe ... -3071812-9
import board
import neopixel
from adafruit_pixel_framebuf import PixelFramebuffer
pixel_pin = board.D6
pixel_width = 8
pixel_height = 4
pixels = neopixel.NeoPixel(
    pixel_pin,
    pixel_width * pixel_height,
    brightness=0.1,
    auto_write=False,
apaul
Post by apaul »
Hi, thanks for the quick reply!
I tried your code, the neopixel import fails"NotImplementedError: Board not supported" (from neopixel_write.py", line 29). I did `export BLINKA_FT232H=1` previously. For reference, that's the `lsusb` output: "Future Technology Devices International, Ltd FT232H Single HS USB-UART/FIFO IC".
As for my previous code, I adjusted it to:
import board
NUM_PIXELS = 256 # (Using the 8x32 matrix)
PIXEL_ORDER = neopixel.RGB
spi = board.SPI()
        spi,
        n=NUM_PIXELS,
        brightness=0.05,
But so far this doesn't work.
FYI:
python3.8 detect.py
Chip id: FT232H
Board id: FTDI_FT232H
Is this a DragonBoard 410c? False
Is this a Pi 3B+? False
Is this a Pi 4B? False
Is this a 40-pin Raspberry Pi? False
Is this a Raspberry Pi Compute Module? False
Is this a BeagleBone Board? False
Is this a Giant Board? False
Is this a Coral Dev Board? False
Is this a Coral Dev Board Mini? False
Is this a SiFive Unleashed? False
Is this a PYNQ Board? False
Is this a Rock Pi board? False
Is this a NanoPi board? False
Is this a Clockwork Pi board? False
Is this an embedded Linux system? False
Is this a generic Linux PC? False
Is this a UDOO Bolt? False
Is this an ASUS Tinker Board? False
Is this an STM32MP1 Board? False
Is this an OS environment variable special case? True
mikeysklar
You have the right idea. You will have to start with your original code and slowly adapt in the example I pasted or other NeoPixel examples to get going.
Here is another example to checkout submitted by a forum user. They were trying to get the NeoPixels to work at 800Hz and only successful at 400Hz.
viewtopic.php?f=47&t=176638&p=860282&hi ... el#p860282
import time
import board
NUM_PIXELS = 1
COLORS = (0xFF0000, 0x00FF00, 0x0000FF)
DELAY = 0.1
spi = board.SPI()
pixels = neopixel.NeoPixel_SPI(spi,
                               NUM_PIXELS,
                               frequency=3200000,
                               auto_write=False)
while True:
    for color in COLORS:
        for i in range(NUM_PIXELS):
            pixels[i] = color
            pixels.show()
            time.sleep(DELAY)
            pixels.fill(0)
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
