Hi all,
I'm using the adafruit_circuitpython libraries, and would like to be able to play a sound file while also doing other things. the cp.play_file() function appears to wait until teh wav file is done playing before the next line will execute. Is there a way to make Python do that function and keep executing the code?
I know I can use audiocore to do this, but using audiocore and the other libs I need to manipulate audio conflicts with the use of adafruit_circuitpython, and I'd love to keep my code as dead simple as possible.
Continuiing execution while using cp.play_file()
- HowdyMoto
- mikeysklar
Re: Continuiing execution while using cp.play_file()
Howdy Moto,
I looked at the source code for the CircuitPlayground and it was quite basic for play_file(). It is going to play through without any sort of background options until the file is finished.
https://github.com/adafruit/Adafruit_Ci ... nd_base.py
def play_file(self, file_name):
"""Play a .wav file using the onboard speaker.
:param file_name: The name of your .wav file in quotation marks including .wav
.. image :: ../docs/_static/speaker.jpg
:alt: Onboard speaker
To use with the Circuit Playground Express or Bluefruit:
.. code-block:: python
from adafruit_circuitplayground import cp
while True:
if cp.button_a:
cp.play_file("laugh.wav")
elif cp.button_b:
cp.play_file("rimshot.wav")
# Play a specified file.
self.stop_tone()
self._speaker_enable.value = True
with self._audio_out(board.SPEAKER) as audio: # pylint: disable=not-callable
wavefile = audiocore.WaveFile(open(file_name, "rb"))
audio.play(wavefile)
while audio.playing:
pass
self._speaker_enable.value = False
- HowdyMoto
Thanks for taking a look, mikeysklar. I discovered that if my code is in the same with block as the play() command, it will keep executing while the sound plays. Here's the code that works as expected: a sound plays while the LEDS light up on my CircuitPlayground Express.
wav_data = open("Tones.wav", "rb")
wav_file = WaveFile(wav_data)
def boot_up():
with AudioOut(board.SPEAKER) as audio:
audio.play(wav_file)
pixels[0] = WHITE
pixels[9] = WHITE
time.sleep(0.05)
pixels[1] = WHITE
pixels[8] = WHITE
time.sleep(0.05)
pixels[2] = WHITE
pixels[7] = WHITE
time.sleep(0.05)
pixels[3] = WHITE
pixels[6] = WHITE
time.sleep(0.05)
pixels[4] = WHITE
pixels[5] = WHITE
time.sleep(0.05)
- mikeysklar
Nicely done. Glad to see audio was a workable solution for you.
