my cpx drive disappears
Play with it! Please tell us which board you're using.
skeilson
Post by skeilson »
this is a windows 10 environment. makecode works. the simulator works. the usb port works. I push the reset button on the hardware and get the green lights. I pair the device in the makecode (right hand side icon). but I still cant download (copy) my code/projects to the cpboot drive (D: drive in my case). Help please!
mikeysklar
Re: my cpx drive disappears
Post by mikeysklar »
If you press the reset button twice does that enter bootloader mode for you? All LEDs go red and then green and there is a pulsing status LED in red? There should be a CPLAYBOOT drive visible on your desktop.
danhalbert
Post by danhalbert »
If you are using MakeCode, then you go to the bootloader by pressing reset only once. If you have CircuitPython or an Arduino program loaded, it takes a double click.
Are you using the browser upload method? If you just download the .uf2, can you drag it to the CPLAYBOOT drive manually?
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
