my cpx drive disappears
- skeilson
this is a windows 10 environment. makecode works. the simulator works. the usb port works. I push the reset button on the hardware and get the green lights. I pair the device in the makecode (right hand side icon). but I still cant download (copy) my code/projects to the cpboot drive (D: drive in my case). Help please!
- mikeysklar
Re: my cpx drive disappears
If you press the reset button twice does that enter bootloader mode for you? All LEDs go red and then green and there is a pulsing status LED in red? There should be a CPLAYBOOT drive visible on your desktop.
- danhalbert
If you are using MakeCode, then you go to the bootloader by pressing reset only once. If you have CircuitPython or an Arduino program loaded, it takes a double click.
Are you using the browser upload method? If you just download the .uf2, can you drag it to the CPLAYBOOT drive manually?
