How to disable internal speaker (Circuit Playground)
Play with it! Please tell us which board you're using.
R99
Post by R99 »
The Circuit Playground Guided Tour mentions you can turn off the internal speaker using the "shutdown control".
https://learn.adafruit.com/adafruit-cir ... uided-tour
However, I can't find guidance on how to implement this in code.
Could someone please point me in the right direction?
I want to use the Audio Pad for output but don't want the internal speaker playing at the same time.
I want to use CircuitPython.
dastels
Re: How to disable internal speaker (Circuit Playground)
Post by dastels »
See the audio example on https://learn.adafruit.com/adafruit-cir ... -audio-out:
# Enable the speaker
speaker_enable = digitalio.DigitalInOut(board.SPEAKER_ENABLE)
speaker_enable.direction = digitalio.Direction.OUTPUT
speaker_enable.value = True
R99
Post by R99 »
Thanks.
Setting that value to False does indeed disable the speaker without disabling the audio pad, which is what I want.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
