Hi, I have some arduino code that's running fine on a CircuitPlayground Classic but it's not working when I upload it onto an Express board. Are there compatibility issues? Is there a different library I should include than Adafruit_CircuitPlayground.h?
Thanks much. :)
Classic code on express board
- catcoffee
Re: Classic code on express board
The code in question:
#include <Adafruit_CircuitPlayground.h>
int NUM_LEDS = 10;
int LED_PIN = 17; //Circuit PlayGround Pin 17
int sensorPin = 12; //Circuit PlayGround Pin 12
bool leftButtonPressed;
bool rightButtonPressed;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
const int HIGH_STRIKE_LIKELIHOOD = 4; //The magic number is 2 to make a strike happen
int LOW_STRIKE_LIKELIHOOD = 10; //Get low likelihood number from sensor, INCREASE this number to make strikes LESS likely
int currentDataPoint = 0;
int chance = HIGH_STRIKE_LIKELIHOOD;
// Simple moving average plot
int NUM_Y_VALUES = 17;
float yValues[] = {
0,
7,
10,
9,
7.1,
7.5,
7.4,
12,
15,
10,
0,
3,
3.5,
4,
1,
7,
1
float simple_moving_average_previous = 0;
float random_moving_average_previous = 0;
float (*functionPtrs[10])(); //the array of function pointers
int NUM_FUNCTIONS = 2;
Serial.begin(9600);
// Neopixel setup
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// initializes the array of function pointers.
functionPtrs[0] = simple_moving_average;
functionPtrs[1] = random_moving_average;
leftButtonPressed = CircuitPlayground.leftButton();
rightButtonPressed = CircuitPlayground.rightButton();
if (chance > 20) {
chance = 20;
if (chance < 3) {
chance = 3;
if (leftButtonPressed) {
Serial.print("UP");
chance = chance + 1;
CircuitPlayground.playTone(500, 100);
Serial.print(chance);
else {
Serial.println(chance);
if (rightButtonPressed) {
//Serial.print("DOWN");
chance = chance - 1;
//Serial.print(chance);
else {
if (random(chance) == 2) {
int led = random(NUM_LEDS);
for (int i = 0; i < 10; i++) {
lightningStrike(random(NUM_LEDS)); //spread out lightnight among multiple LEDs.
// Once there's been one strike, I make it more likely that there will be a second.
//chance = HIGH_STRIKE_LIKELIHOOD;
//} else {
//chance = LOW_STRIKE_LIKELIHOOD;
turnAllPixelsOff();
delay(500);
void turnAllPixelsOff() {
for (int i = 0; i < NUM_LEDS; i++) {
strip.setPixelColor(i, 0);
strip.show();
void lightningStrike(int pixel) {
float brightness = callFunction(random(NUM_FUNCTIONS));
float scaledWhite = abs(brightness*500);
strip.setPixelColor(pixel, strip.Color(scaledWhite, scaledWhite, scaledWhite));
strip.show();
delay(random(5, 80)); // Read value from sensor to change length of possible delays between flashes
currentDataPoint++;
currentDataPoint = currentDataPoint%NUM_Y_VALUES;
float callFunction(int index) {
return (*functionPtrs[index])(); //calls the function at the index of `index` in the array
// https://en.wikipedia.org/wiki/Moving_average#Simple_moving_average
float simple_moving_average() {
uint32_t startingValue = currentDataPoint;
uint32_t endingValue = (currentDataPoint+1)%NUM_Y_VALUES;
float simple_moving_average_current = simple_moving_average_previous +
(yValues[startingValue])/NUM_Y_VALUES -
(yValues[endingValue])/NUM_Y_VALUES;
simple_moving_average_previous = simple_moving_average_current;
return simple_moving_average_current;
// Same as simple moving average, but with randomly-generated data points.
float random_moving_average() {
float firstValue = random(1, 10);
float secondValue = random(1, 10);
float random_moving_average_current = random_moving_average_previous +
firstValue/NUM_Y_VALUES -
secondValue/NUM_Y_VALUES;
random_moving_average_previous = random_moving_average_current;
return random_moving_average_current;
- jerryn
comparing the Pinouts
https://learn.adafruit.com/adafruit-cir ... ss/pinouts
and
https://learn.adafruit.com/introducing- ... nd/pinouts
It tools like the Neopixels are on pin 8 for the CPX and 17 for the Classic.
Note: I do not represent Adafruit. Just trying to help.
Edited to add: there are also some notes about pin 12 (D0) for the CPX in the guide.
and
- catcoffee
Doh! Thanks so much for that, I had just assumed the pinouts were the same. Won't make that mistake twice.
Thanks again!
Thanks again!
