Time-based trigger
Play with it! Please tell us which board you're using.
PalB09
Time-based trigger
Post by PalB09 »
Hi Team,
I am using Circuit Playground Bluefruit. I am turning the on-board NeoPixels on using capacitive touch and I need the NeoPixels to turn off at a particular time every day. Is that possible? Can Bluefruit perform time-based operations?
Any suggestion will be very appreciated.
Thank you,
Pallabi
dastels
Re: Time-based trigger
Post by dastels »
That's a challenge since the CircuiutPlaygrounds don't have an onboard real-time-clock and without WiFi it can't query a time server regularly to sync it's internal timekeeping. You can add either of those things, but you'd loose cap-touch pads in the process. A real time clock would have the least impact as you'd just use 2 pads for it (SDA and SCL).
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
