I bought a Circuit Playground Bluefruit from Adafruit, it arrived about 5 days ago.
It was working, then this happened:
I had circuit python installed(7.0.0), it was working perfectly.
Then sometime about 2 or 3 days ago, Circuitpython stopped working.
When I plug in the CPB, the CIRCUITPY drive doesn't show up.
So the most obvious course of action would be to reinstall circuit python.
I reinstalled circuitpython I don't know how many times.
When you double click reset, all the neopixels turn red, then green, and then the CPLAYBOOT drive shows up, as expected.
I dragged the circuitpython .uf2 file into the CPLAYBOOT drive, then the drive disappears, as expected.
The CPB reboots, but the CIRCUITPY drive still doesn't show up.
P.S. The neopixels blink green, wait about 5 seconds, then repeat the cycle.
I don't know if that will help you.
Problem with CIrcuitpython on CPB
- danhalbert
Re: Problem with CIrcuitpython on CPB
Your program could be crashing, before CIRCUITPY has a chance to appear.
Seethe troubleshooting instructions here: https://learn.adafruit.com/welcome-to-c ... 2978456-24
If you can connect to the board via the REPL ("Serial" in Mu), you can clear and reformat CIRCUITPY.
Try getting into safe mode as described here: https://learn.adafruit.com/welcome-to-c ... 3105351-25
Then erase CIRCUITPY as described here: https://learn.adafruit.com/welcome-to-c ... 2987288-32
Or, use the special "erase" UF2 listed here: https://learn.adafruit.com/welcome-to-c ... 2978458-37.
Choose the one for Circuit Playground Bluefruit, and drag it to the BOOT drive. Then you will need to reload CircuitPython.
- Insert_Name_Here
When I try using the erase script, it doesn't work. And I couldn't find an erase bootloader for CPB, only CPX.
- danhalbert
Here is where to find it:
https://cdn-learn.adafruit.com/assets/a ... 1572026649
and here is the direct link:https://cdn-learn.adafruit.com/assets/a ... 1572026649
- Insert_Name_Here
Sorry, I didn't see that(lol).
- Insert_Name_Here
The bootloader erased the filesystem(I think) and then I installed circuitpython. CIRCUITPY still not showing up.
- danhalbert
Do you have some other computers you can try, even an RPi? What is the computer you are using now? If you have not rebooted it, try that.
(Aside on terminology: It's not a bootloader, but an erase program. The bootloader displays the boot drive. CircuitPython is not a bootloader either.)
- Insert_Name_Here
I'm using Linux Mint 20.1 MATE 64-bit. Maybe I could try my dad's Mac Book Pro...
- danhalbert
I am using Ubuntu 20.04 with Cinnamon. Sometimes /media/<username>/CIRCUITPY gets stuck and doesn't go away, and you have to remove it by hand with sudo. But if it's stuck, the board shows up as CIRCUITPY1
- Insert_Name_Here
?danhalbert wrote:I am using Ubuntu 20.04 with Cinnamon. Sometimes /media/<username>/CIRCUITPY gets stuck and doesn't go away, and you have to remove it by hand with sudo. But if it's stuck, the board shows up as CIRCUITPY1
- danhalbert
Sometimes Ubuntu has had USB problems and hung. If I force reboot, a /media/myusername/CIRCUITPY may remain present even with no board plugged in. You have to remove it by hand with `sudo rmdir /media/myusername/CIRCUITPY`.
- Insert_Name_Here
I tried cdingdanhalbert wrote:Sometimes Ubuntu has had USB problems and hung. If I force reboot, a /media/myusername/CIRCUITPY may remain present even with no board plugged in. You have to remove it by hand with `sudo rmdir /media/myusername/CIRCUITPY`.
It can't find that directory.
- danhalbert
If you don't have it, then that is not your problem.
Did you try the board on another computer?
- Insert_Name_Here
No. I just realized Mac Book Pros only have type C USB. I don't have a type C to C USB cable.
- Insert_Name_Here
I was reading circuit python troubleshooting info and I found this:
So, it is blinking green, meaning code finished without error? Well where is the circuitpy drive with the code? What program is it running?CircuitPython 7.0.0 and Later
The status LED blinks were changed in CircuitPython 7.0.0 in order to save battery power and simplify the blinks. These blink patterns will occur on single color LEDs when the board does not have any RGB LEDs. Speed and blink count also vary for this reason.
On start up, the LED will blink YELLOW multiple times for 1 second. Pressing reset during this time will restart the board and then enter safe mode. On Bluetooth capable boards, after the yellow blinks, there will be a set of faster blue blinks. Pressing reset during the BLUE blinks will clear Bluetooth information and start the device in discoverable mode, so it can be used with a BLE code editor.
Once started, CircuitPython will blink a pattern every 5 seconds when no user code is running to indicate why the code stopped:
1 GREEN blink: Code finished without error.
2 RED blinks: Code ended due to an exception. Check the serial console for details.
3 YELLOW blinks: CircuitPython is in safe mode. No user code was run. Check the serial console for safe mode reason.
