dastels wrote:I think this may be the crux of the problem:
Multiple libraries were found for "Adafruit_CircuitPlayground.h"
Fix that and see how things are. I would delete the Adafruit_Circuit_Playground library from inside Arduino, then make sure both
C:\Users\d3vco\BANNED\Documents\Arduino\libraries\Adafruit_Circuit_Playground and
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground are gone (remove any still present) then reinstall the Adafruit_Circuit_Playground library.
Thank you Dave for the quick feedback. I searched those folders and deleted as suggested and reinstalled the library. However, I have an error still. Though it seems the duplicate issues is gone? Below is just the error. In the code section is the entire compiling sequence.
In file included from C:\Users\d3vco\BANNED\Documents\Arduino\Sparkle_Skirt\Sparkle_Skirt.ino:2:0:
C:\Users\d3vco\BANNED\Documents\Arduino\libraries\FastLED\src/FastLED.h:14:21: note: #pragma message: FastLED version 3.004.000
# pragma message "FastLED version 3.004.000"
In file included from C:\Users\d3vco\BANNED\Documents\Arduino\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:30:0,
from C:\Users\d3vco\BANNED\Documents\Arduino\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3,
from C:\Users\d3vco\BANNED\Documents\Arduino\Sparkle_Skirt\Sparkle_Skirt.ino:1:
C:\Users\d3vco\BANNED\Documents\Arduino\libraries\Adafruit_Circuit_Playground/utility/CPlay_CapacitiveSensor.h:25:15: error: conflicting declaration 'typedef volatile uint8_t uint8_t'
#define RwReg uint8_t
C:\Users\d3vco\BANNED\Documents\Arduino\libraries\FastLED\src/platforms/avr/led_sysdefs_avr.h:17:32: note: in expansion of macro 'RwReg'
typedef volatile uint8_t RwReg; /**< Read-Write 8-bit register (volatile unsigned int) */
In file included from c:\program files (x86)\arduino\hardware\tools\avr\lib\gcc\avr\7.3.0\include\stdint.h:9:0,
from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\inttypes.h:37,
from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\pgmspace.h:88,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28,
from C:\Users\d3vco\AppData\Local\Temp\arduino_build_591093\sketch\Sparkle_Skirt.ino.cpp:1:
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\stdint.h:126:22: note: previous declaration as 'typedef unsigned char uint8_t'
typedef unsigned int uint8_t __attribute__((__mode__(__QI__)));
Arduino: 1.8.16 (Windows 10), Board: "Adafruit Circuit Playground"
The sketch name had to be modified.
Sketch names must start with a letter or number, followed by letters,
numbers, dashes, dots and underscores. Maximum length is 63 characters.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\d3vco\BANNED\Documents\Arduino\libraries -fqbn=arduino:avr:circuitplay32u4cat -vid-pid=239A_8011 -ide-version=10816 -build-path C:\Users\d3vco\AppData\Local\Temp\arduino_build_591093 -warnings=none -build-cache C:\Users\d3vco\AppData\Local\Temp\arduino_cache_773131 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\d3vco\BANNED\Documents\Arduino\Sparkle_Skirt\Sparkle_Skirt.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\d3vco\BANNED\Documents\Arduino\libraries -fqbn=arduino:avr:circuitplay32u4cat -vid-pid=239A_8011 -ide-version=10816 -build-path C:\Users\d3vco\AppData\Local\Temp\arduino_build_591093 -warnings=none -build-cache C:\Users\d3vco\AppData\Local\Temp\arduino_cache_773131 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\d3vco\BANNED\Documents\Arduino\Sparkle_Skirt\Sparkle_Skirt.ino
Using board 'circuitplay32u4cat' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "C:\\Users\\d3vco\\AppData\\Local\\Temp\\arduino_build_591093\\sketch\\Sparkle_Skirt.ino.cpp" -o nul
Alternatives for Adafruit_CircuitPlayground.h: [[email protected]]
ResolveLibrary(Adafruit_CircuitPlayground.h)
-> candidates: [[email protected]]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "C:\\Users\\d3vco\\AppData\\Local\\Temp\\arduino_build_591093\\sketch\\Sparkle_Skirt.ino.cpp" -o nul
Alternatives for SPI.h: [[email protected]]
ResolveLibrary(SPI.h)
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\d3vco\\AppData\\Local\\Temp\\arduino_build_591093\\sketch\\Sparkle_Skirt.ino.cpp" -o nul
Alternatives for Wire.h: [[email protected]]
ResolveLibrary(Wire.h)
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\d3vco\\AppData\\Local\\Temp\\arduino_build_591093\\sketch\\Sparkle_Skirt.ino.cpp" -o nul
Alternatives for FastLED.h: [[email protected]]
ResolveLibrary(FastLED.h)
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\AppData\\Local\\Temp\\arduino_build_591093\\sketch\\Sparkle_Skirt.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\Adafruit_CircuitPlayground.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_CPlay_FreeTouch.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_CPlay_LIS3DH.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_CPlay_Mic.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_CPlay_NeoPixel.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_CPlay_Speaker.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_ZeroPDM.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\CP_Firmata.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\CPlay_CapacitiveSensor.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibDecodeBase.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibHardware.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibProtocols.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibRecvBase.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibRecvPCI.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibSAMD21.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibSendBase.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\talkie.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\utility\\twi.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\FastLED.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\bitswap.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\colorpalettes.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\colorutils.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\hsv2rgb.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\lib8tion.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\noise.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\platforms\\esp\\32\\clockless_rmt_esp32.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\platforms.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\power_mgt.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src\\wiring.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\AppData\\Local\\Temp\\arduino_build_591093\\sketch\\Sparkle_Skirt.ino.cpp" -o "C:\\Users\\d3vco\\AppData\\Local\\Temp\\arduino_build_591093\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\d3vco\\AppData\\Local\\Temp\\arduino_build_591093\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10816 -DARDUINO_AVR_CIRCUITPLAY -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8011 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground\"" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\circuitplay32u4" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\d3vco\\BANNED\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\d3vco\\AppData\\Local\\Temp\\arduino_build_591093\\sketch\\Sparkle_Skirt.ino.cpp" -o "C:\\Users\\d3vco\\AppData\\Local\\Temp\\arduino_build_591093\\sketch\\Sparkle_Skirt.ino.cpp.o"
[b]In file included from C:\Users\d3vco\BANNED\Documents\Arduino\Sparkle_Skirt\Sparkle_Skirt.ino:2:0:
^~~~~~~[/b]
Using library Adafruit_Circuit_Playground at version 1.11.3 in folder: C:\Users\d3vco\BANNED\Documents\Arduino\libraries\Adafruit_Circuit_Playground
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library FastLED at version 3.4.0 in folder: C:\Users\d3vco\BANNED\Documents\Arduino\libraries\FastLED
exit status 1
Error compiling for board Adafruit Circuit Playground.
