I have a Circuit Playground Express that I'm using for a project. Should be a pretty simple thing - I have 6 screws in a 3d printed Star Wars Holocron that are run to A1-A6 on the board. If it detects all 6 are currently touched it will light up after a few seconds.
The issue I'm having is that it doesn't reliably detect all the touches every check (I have a 0.1 debounce). In fact, when I have all 6 touched sometimes I only see 1 or maybe 2 being touched (see code below for how I'm outputting which are touched). I've even implemented a count of how many are touched and made allowances so that if it miss detects 1 of the pads it'll still count - but even that isn't reliable.
Am I missing something obvious? If I only touch one at a time it outputs the correct pad number. And I've dropped the sensitivity very low. I would LOVE any suggestions!
import time
from adafruit_circuitplayground.express import cpx
cpx.adjust_touch_threshold(1)
RED = (90, 0, 0)
BLACK = (0, 0, 0)
vals = (
0, 1, 2, 3, 4, 5, 7, 9, 12,
15, 18, 22, 27, 32, 38, 44, 51, 58,
67, 76, 86, 96, 108, 120, 134, 148, 163,
180, 197, 216, 235, 255
FADE_DURATION = 3
FADE_STEP_DURATION = FADE_DURATION / len(vals)
cpx.pixels.fill(RED)
cpx.pixels.brightness = 0 # set brightness value
holdDuration = 10
curBrightness = 0
curStep = 0
touched = False
COMPLETE = False
TOTALTOUCHES = 0
STRING = ""
while True:
if not COMPLETE:
TOTALTOUCHES = 0
STRING = ""
if cpx.touch_A1:
TOTALTOUCHES += 1
STRING += "1 "
if cpx.touch_A2:
TOTALTOUCHES += 1
STRING += "2 "
if cpx.touch_A3:
TOTALTOUCHES += 1
STRING += "3 "
if cpx.touch_A4:
TOTALTOUCHES += 1
STRING += "4 "
if cpx.touch_A5:
TOTALTOUCHES += 1
STRING += "5 "
if cpx.touch_A6:
TOTALTOUCHES += 1
STRING += "6 "
now = time.monotonic()
print(STRING)
if TOTALTOUCHES >= 5:
print("pass")
if touched is False:
touchStartTime = time.monotonic()
touched = True
if now - touchStartTime > holdDuration and touched is True:
if curBrightness < 1:
curStep += 1
curBrightness = vals[curStep] / 255
# print(curBrightness)
cpx.pixels.brightness = curBrightness
time.sleep(FADE_STEP_DURATION)
if curBrightness >= 1:
cpx.play_file("test.wav")
cpx.pixels.brightness = 1
COMPLETE = True
time.sleep(0.1)
else:
touched = False
curBrightness = 0
curStep = 0
cpx.pixels.fill(BLACK)
# print(now)
time.sleep(0.1)
