Error compiling on Circuit Pplayground Bluefruit
Play with it! Please tell us which board you're using.
mbmosher
Post by mbmosher »
Hi Folks, I'm getting the following error when trying to compile any of the circuit playground library example code for the circuit playground bluefruit.
I'm on OSX 10.14.6, python 2.7.16, Arduino 1.8.19, Adafruit nRF52 1.2.0, Adafruit circuit playground 1.11.4
I've tried deleting the Library >Arduino15 folder, and reinstalling the board files, no change in error.
Thanks for the help!
[59438] Error loading Python lib '/var/folders/5k/_vtvth091bj75_wp0hxtf7r80000gq/T/_MEIyxO5PC/libpython3.8.dylib': dlopen: dlopen(/var/folders/5k/_vtvth091bj75_wp0hxtf7r80000gq/T/_MEIyxO5PC/libpython3.8.dylib, 10): Symbol not found: _preadv
  Referenced from: /var/folders/5k/_vtvth091bj75_wp0hxtf7r80000gq/T/_MEIyxO5PC/libpython3.8.dylib (which was built for Mac OS X 11.1)
  Expected in: /usr/lib/libSystem.B.dylib
 in /var/folders/5k/_vtvth091bj75_wp0hxtf7r80000gq/T/_MEIyxO5PC/libpython3.8.dylib
exit status 255
/Applications/Arduino.app/Contents/Java/arduino-builder returned 255
Error compiling for board Adafruit Circuit Playground Bluefruit.
Franklin97355
Re: Error compiling on Circuit Pplayground Bluefruit
Post by Franklin97355 »
I don't know apples enough but just wondering, if you are using python 2.7.16 why does the program look for "Referenced from:
/var/folders/5k/_vtvth091bj75_wp0hxtf7r80000gq/T/_MEIyxO5PC/libpython3.8.dylib (which was built for Mac OS X 11.1)"
mbmosher
Post by mbmosher »
Hi thanks, good catch. Turns out I did not have Python 3 installed, so I did. Deleted Arduino15 again, but still getting the same error. Confirmed python 3.8 installed in terminal.
adafruit2
Post by adafruit2 »
yeah you have some core issue with your arduino install and python setup
look at
viewtopic.php?f=25&t=168759
mbmosher
Post by mbmosher »
Thank you, that fixed it!
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
