I recently decided to try to learn programming and electronics after losing my workshop/house to the CA fires. The problem is I can't get anything to upload on either my rpi or my win 10 pc. I've tried gemma m0 and circuit playground. no arduino code ever makes it onto the boards. hell i cant even get it to compile. I've messed with it so much trying to get it to work that I'm more lost than when i started.
The only code I've successfully loaded is a basic cap touch light change i wrote for flora months ago.
this is the demo example for cpb
/home/pi/.arduino15/packages/adafruit/tools/arm-none-eabi-gcc/9-2019q4/bin/arm-none-eabi-ar: error while loading shared libraries: libfl.so.2: cannot open shared object file: No such file or directory
Using library Adafruit_Circuit_Playground at version 1.11.4 in folder: /home/pi/Arduino/libraries/Adafruit_Circuit_Playground
Using library SPI at version 1.0 in folder: /home/pi/.arduino15/packages/adafruit/hardware/nrf52/1.3.0/libraries/SPI
Using library Wire at version 1.0 in folder: /home/pi/.arduino15/packages/adafruit/hardware/nrf52/1.3.0/libraries/Wire
this is the touch penant for gemma m0
"/home/pi/.arduino15/packages/adafruit/tools/arm-none-eabi-gcc/9-2019q4/bin/arm-none-eabi-ar" rcs "/tmp/arduino_build_947558/core/core.a" "/tmp/arduino_build_947558/core/pulse_asm.S.o"
Using library Adafruit_FreeTouch_Library at version 1.1.1 in folder: /home/pi/Arduino/libraries/Adafruit_FreeTouch_Library
Using library FastLED at version 3.4.0 in folder: /home/pi/Arduino/libraries/FastLED
exit status 127
Error compiling for board Adafruit Gemma M0.
Using library PDM at version 1.0 in folder: /home/pi/.arduino15/packages/adafruit/hardware/nrf52/1.3.0/libraries/PDM
Using library Adafruit_TinyUSB_Arduino at version 1.7.0 in folder: /home/pi/.arduino15/packages/adafruit/hardware/nrf52/1.3.0/libraries/Adafruit_TinyUSB_Arduino
exit status 127
Error compiling for board Adafruit Circuit Playground Bluefruit.
cant get arduino to work
- hatem0
Re: cant get arduino to work
did you download adafruit avr board from the board manager.
Make sure you download the correct library if you are using library.
- adafruit_support_carter
The Gemma M0 uses a SAMD21. The Circuit Playground Bluefruit uses a nRF52840. Both of these are ARM based microcontrollers. Not AVR.
But do make sure you have all the necessary Board Support Packages (BSP) installed.
See here for Gemma M0:
https://learn.adafruit.com/adafruit-gem ... -ide-setup
See here for CPB:
https://learn.adafruit.com/adafruit-cir ... port-setup
See here for CPB:
- zcgdzip
I have the correct libraries installed. Both the Adafruit and Arduino SAMD libraries and the Adafruit NRF52 library.
Let's focus on the Gemma M0 for now.
Are you getting those error messages when trying to upload the Blink example?
https://learn.adafruit.com/adafruit-gem ... 2854174-21
