Have found a number of topics on this issue, followed a number of suggestions others have tried with no success.
The gizmo works with the https://cdn-learn.adafruit.com/assets/a ... 1576641935
But does not work with Circuitpython.
Boot_out.txt
Adafruit CircuitPython 7.2.0 on 2022-02-24; Adafruit Circuit Playground Bluefruit with nRF52840
Board ID:circuitplayground_bluefruit
REPL in MU
When run displays.
Code done running,,no errors.
Modules list
>>> help("modules")
__main__ board microcontroller sharpdisplay
_bleio builtins micropython storage
adafruit_bus_device busio msgpack struct
adafruit_pixelbuf collections neopixel_write supervisor
aesio countio onewireio synthio
alarm digitalio os sys
analogio displayio paralleldisplay terminalio
array errno pulseio time
atexit fontio pwmio touchio
audiobusio framebufferio rainbowio traceback
audiocore gc random ulab
audiomixer getpass re usb_cdc
audiomp3 gifio rgbmatrix usb_hid
audiopwmio io rotaryio usb_midi
binascii json rtc uselect
bitbangio keypad sdcardio vectorio
bitmaptools math select watchdog
Plus any modules on the filesystem
Any suggestions?
CPB and GIZMO black screen
- eng1user
- list of installed libraries
- lib.png (9.63 KiB) Viewed 93 times
- adafruit_support_carter
Re: CPB and GIZMO black screen
The code is completing and exiting. When that happens, things reset and the display can be lost. One way to prevent that is to add an infinite loop at the very end of your code so it won't exit:When run displays.
while True:
pass
https://github.com/adafruit/Adafruit_Ci ... ft_demo.py
It uses the gizmo library (same repo).
