Following guide for CPG Express with TFT gizmo.
On Arduino IDE v1.8.16, after loading libraries and restarting IDE, ran code and got this ERROR: 'SPI1' was not declared in this scope.
Looking at code, I see:
"You will need to use Adafruit's CircuitPlayground Express Board Definition
// for Gizmos rather than the Arduino version since there are additional SPI
// ports exposed."
How do I do this?Arduino IDE only shows CircuitPlayground board.
Does the code have to be modified? If so, what changes must be made?
Arduino: 1.8.16 (Windows 10), Board: "Adafruit Circuit Playg
- FrankBS
- dastels
Re: Arduino: 1.8.16 (Windows 10), Board: "Adafruit Circuit P
Have you installed the Arduino AND Adafruit SAMD board support packages?
- FrankBS
Not sure of SAMD board support package. Is that a library or do I load it under preferences?
Frank
Frank
- dastels
In the board manager. I suggest you read the CircuitPlayground tutorial guide, starting here: https://learn.adafruit.com/adafruit-cir ... ss/arduino
- FrankBS
Thanks, getting there. But now the following displays when loading graphicstest_tft_gizmo. The tft activates but nothing else happens.
Sketch uses 34636 bytes (13%) of program storage space. Maximum is 262144 bytes.
Global variables use 3740 bytes (11%) of dynamic memory, leaving 29028 bytes for local variables. Maximum is 32768 bytes.
Atmel SMART device 0x10010005 found
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v1.1 [Arduino:XYZ] Jan 15 2022 11:53:59
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.840 seconds
Write 34636 bytes to flash (542 pages)
[==============================] 100% (542/542 pages)
done in 0.280 seconds
Verify 34636 bytes of flash with checksum.
Verify successful
done in 0.057 seconds
CPU reset.
Chip ID : 10010005
Address : 8192
Pages : 3968
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Erase flash
Verify successful
CPU reset.
- FrankBS
I have reloaded all ADAFRUIT libraries to IDE. Reloaded CP 7.2.4 UF2 to the board. Re-run graphicstest_tft_gizmo and the code compiles and runs resulting in message shown in my previous pose. I then lose the circuitplayground drive and it reloads the CLAYBOOT drive and then that drive goes away.
If I double click on the CP Express board, I am right back to where I started,
- dastels
Are you trying to use CircuitPython or C++/Arduino? It's one or the other.
- FrankBS
Sorry but that is a strange question. I have been trying to use circuit python. What makes you think I am trying to use C++/Arduino?
Wait.... I see that in the IDE I am using an Arduino defined "Adafruit Circuit Playground Express" from the Arduino SAMD board.
I cannot see a " Circuit Playground Express" Board only "Circuit Playground Classic" in the Adafruit Board choices.
Should there be a " Circuit Playground Express" board in the Adafruit board selection in the IDE? Should I select one of the other boards?
After running the sketch and receiving results in the error that seems to re-flash the playground board, I lose connection on my computer resulting in the need to reset the board in bootloader.
