While waiting to get graphicstest_tft_gizmo to work using Arduino IDE (with help from forum folks), I moved on to "Circuit Playground Express with Displayio".
I loaded the specific UF2 file and then made sure I had all of the libraries installed. I loaded the sample CircuitPython Code Example into Mu (which I am growing to hate), and saved (ran) it as code.py.
Received the following error:
File "code.py", line 20, in <module>
MemoryError: memory allocation failed, allocating 7680 bytes
Code done running.
Now what have I done wrong? I know I should be positive in my postings but I am getting quite annoyed. I want to move on to some projects but can't get past the example codes.
- dastels
Re: Circuit Playground Express with Displayio
You're using the latest version of CircuitPython and libraries?
If so, try using an older version. Maybe 6.x
There won't be any memory problems using C++/Arduino.
A better solution for CircuitPython is to switch to a CircuitPlayground Bluefruit which has a more capable MCU with significantly more memory.
- FrankBS
Thanks.
Will keep in mind.
Got things working now with Feather2040 and display Featherwing.
Will keep in mind.
