ThinkInk weather station
Play with it! Please tell us which board you're using.
lostcity
Post by lostcity »
I have loaded code from adafruit on my Pi zero w in the hopes i can use it as desktop weather station. I have loaded the code for python and copied the code for weather station. I do have an api key and it appeats correct. I get the attached error message when I try to run python3 code.py
adafruit_support_carter
Re: ThinkInk weather station
You need to enable SPI, which can be done in raspi-config.
The guide here covers the general process for setting up a Pi to use CircuitPython libraries:
https://learn.adafruit.com/circuitpytho ... spberry-pi
lostcity
Post by lostcity »
Doh! I should have seen that after looking at the wiring. Thanks. It works.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
