Board I2C Not Compiling
Play with it! Please tell us which board you're using.
jlaiosa
Post by jlaiosa »
Adafruit CircuitPython 7.2.5. I am try to use a sample code the sets up the I2C as follows: i2c = board.I2C(). This gives an error: AttributeError: 'module' object has no attribute 'I2C' which would indicate that is is not defined. I can define LED's with not error. I am using a wrong version of board.
Thanks.
mikeysklar
Re: Board I2C Not Compiling
Post by mikeysklar »
Are you running this on a Circuit Playground Express?
That initialization you are using is correct.
i2c = board.I2C()
Can you paste in the full code maybe something else is going on?
jlaiosa
Post by jlaiosa »
Here is the sample code I downloaded. I am using a Raspberry Pi Pico.
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: Unlicense
Author: Mark Roberts (mdroberts1243) from Adafruit code
This test will initialize the display using displayio and draw a solid white
background, a smaller black rectangle, miscellaneous stuff and some white text.
import board
import displayio
import terminalio
# can try import bitmap_label below for alternative
from adafruit_display_text import label
import adafruit_displayio_sh1107
displayio.release_displays()
# oled_reset = board.D9
# Use for I2C
i2c = board.I2C()
display_bus = displayio.I2CDisplay(i2c, device_address=0x3C)
# SH1107 is vertically oriented 64x128
WIDTH = 128
HEIGHT = 64
BORDER = 2
display = adafruit_displayio_sh1107.SH1107(
display_bus, width=WIDTH, height=HEIGHT, rotation=0
# Make the display context
splash = displayio.Group()
display.show(splash)
color_bitmap = displayio.Bitmap(WIDTH, HEIGHT, 1)
color_palette = displayio.Palette(1)
color_palette[0] = 0xFFFFFF # White
bg_sprite = displayio.TileGrid(color_bitmap, pixel_shader=color_palette, x=0, y=0)
splash.append(bg_sprite)
# Draw a smaller inner rectangle in black
inner_bitmap = displayio.Bitmap(WIDTH - BORDER * 2, HEIGHT - BORDER * 2, 1)
inner_palette = displayio.Palette(1)
inner_palette[0] = 0x000000 # Black
inner_sprite = displayio.TileGrid(
inner_bitmap, pixel_shader=inner_palette, x=BORDER, y=BORDER
splash.append(inner_sprite)
# Draw some white squares
sm_bitmap = displayio.Bitmap(8, 8, 1)
sm_square = displayio.TileGrid(sm_bitmap, pixel_shader=color_palette, x=58, y=17)
splash.append(sm_square)
med_bitmap = displayio.Bitmap(16, 16, 1)
med_square = displayio.TileGrid(med_bitmap, pixel_shader=color_palette, x=71, y=15)
splash.append(med_square)
lrg_bitmap = displayio.Bitmap(32, 32, 1)
lrg_square = displayio.TileGrid(lrg_bitmap, pixel_shader=color_palette, x=91, y=28)
splash.append(lrg_square)
# Draw some label text
text1 = "0123456789ABCDEF123456789AB" # overly long to see where it clips
text_area = label.Label(terminalio.FONT, text=text1, color=0xFFFFFF, x=8, y=8)
splash.append(text_area)
text2 = "SH1107"
text_area2 = label.Label(
terminalio.FONT, text=text2, scale=2, color=0xFFFFFF, x=9, y=44
splash.append(text_area2)
while True:
pass
jlaiosa
Post by jlaiosa »
I figured it out. For Raspberry Pi Pico you need to use the busio library.
Thanks for everybody's time.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
