CIRCUITPLAYGROUND CLASSIC- DC MOTOR INTERFACE
Play with it! Please tell us which board you're using.
bmink1234
Post by bmink1234 »
I have been struggling to get my Classic Circuitplayground to work with a small toy 3V DC motor. I connect pin 2 to base of NPN transistor (through a 1k resistor)and emitter to ground. Collector to one side of motor. Positive side of motor going to external battery pack +3VDC. External Battery pack negative connects to GND of CircuitPlayground. CircuitPlayground is powered by USB cable. I also have a flyback diode across dc Motor. The motor does not come on. When I replace the motor with a sequin LED it works perfectly and is very bright so I know my code and transistor is working just fine. The DC motor works just fine when powered directly across the 3VDC battery supply. Any ideas why this doesn't work?
I am using a 2N3904 NPN transistor and a 1N4001 diode. Resistor from Circuit Playground to base of transistor is 1k.
See the link below to see how I have connected everything up.
https://techexplorations.com/guides/ard ... ransistor/
Re: CIRCUITPLAYGROUND CLASSIC- DC MOTOR INTERFACE
Does the motor show any signs of trying to move? If you give it a spin by hand does it keep on going?
bmink1234
Post by bmink1234 »
Nope. I gave it a little push..nothing..dead as can be.
bmink1234
Post by bmink1234 »
Perhaps I should get a multimeter out and check the amount of current going through the emitter to ground as it is configured now.. And then check the current when I connect just the fan and the battery pack (2 x 1.5V AA batteries). Maybe the transistor emitter to ground is not getting enough current?
Some current measurements would be helpful. The 2N3904 is only rated for about 200mA. That may be sufficient to keep a small motor running. But the startup current is typically several times higher.
bmink1234
Post by bmink1234 »
Thanks. I will check it out tomorrow.
bmink1234
Post by bmink1234 »
So I found the DC motor was drawing way more current than I expected.. like well over 500mA. I don't have another transistor so I ended up just ditching the original DC motor in favor of a small brushless motor/fan. Hooked it up instead of the motor and everything is working well now.
Hooked up fan similar to the link shown here. https://web.cecs.pdx.edu/~gerry/class/I ... ernal/fan/
Good to hear you found a combination that works. Thanks for the follow-up.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
