My goal is to trigger a countdown timer with lights and sound. Everything works, except the external trigger button state is reversed. Right now the countdown triggers if I do not push the button. If the button is pushed, the timer will not start. I want the opposite behavior (pushing the button triggers the countdown) The code is below, but before I get to it I'll describe the two things I have tried.
1. I tried to uncomment out line 22 and comment out line 23 so that it became
Pull.DOWN
Pull.UP
2. I tried to change
if button.value:
if button.value = FALSE:
button.value = False:
Thank you for any help!
# Circuit Playground NeoPixel
import time
import board
import neopixel
import digitalio
#stuff specific to the sound part
import array
import math
####Light'n button stuff ######
#set up the pixels
pixels = neopixel.NeoPixel(board.A2, 30, brightness=0.8, auto_write=False)
#sets the button variable
#button = digitalio.DigitalInOut(board.BUTTON_A)
#button = digitalio.DigitalInOut(board.A5)
#makes pushing the button activate it
#button.switch_to_input(pull=digitalio.Pull.DOWN)
button.switch_to_input(pull=digitalio.Pull.UP)
led = digitalio.DigitalInOut(board.D13)
led.switch_to_output()
#color variables
RED = (255, 0, 0)
YELLOW = (255, 150, 0)
GREEN = (0, 255, 0)
CYAN = (0, 255, 255)
BLUE = (0, 0, 255)
PURPLE = (180, 0, 255)
WHITE = (255, 255, 255)
BLACK = (0, 0, 0)
color_chase_wait_time = 0.02
#####Audio stuff########
try:
from audiocore import RawSample
except ImportError:
from audioio import RawSample
try:
from audioio import AudioOut
except ImportError:
try:
from audiopwmio import PWMAudioOut as AudioOut
except ImportError:
pass # not always supported by every board!
FREQUENCY = 440 # 440 Hz middle 'A'
SAMPLERATE = 8000 # 8000 samples/second, recommended!
# Generate one period of sine wav.
length = SAMPLERATE // FREQUENCY
sine_wave = array.array("H", [0] * length)
for i in range(length):
sine_wave[i] = int(math.sin(math.pi * 2 * i / length) * (2 ** 15) + 2 ** 15)
# Enable the speaker
speaker_enable = digitalio.DigitalInOut(board.SPEAKER_ENABLE)
speaker_enable.direction = digitalio.Direction.OUTPUT
speaker_enable.value = True
audio = AudioOut(board.SPEAKER)
sine_wave_sample = RawSample(sine_wave)
def yellow_flash(FLASH_TIME):
pixels.fill(BLACK)
pixels.show()
time.sleep(FLASH_TIME)
pixels.fill(YELLOW)
pixels.show()
#####rest of code######
def color_chase(color, wait):
for i in range(30):
pixels[i] = color
time.sleep(wait)
pixels.show()
#time.sleep(1)
while True:
if button.value: #if button is pushed
#green during the first ~40 seconds? (need to update time for all of this)
pixels.fill(GREEN)
pixels.show()
led.value = True
time.sleep(45)
#yellow flashing for ~10 seconds?
pixels.fill(YELLOW)
pixels.show()
time.sleep(2)
yellow_flash(.5)
yellow_flash(.5)
yellow_flash(.5)
yellow_flash(.5)
yellow_flash(.5)
yellow_flash(.5)
yellow_flash(.5)
yellow_flash(.5)
#color chase for last ~5 seconds?
# Increase the number to slow down the color chase
color_chase(YELLOW, color_chase_wait_time)
color_chase(CYAN, color_chase_wait_time)
color_chase(BLUE, color_chase_wait_time)
color_chase(PURPLE, color_chase_wait_time)
color_chase(BLACK, color_chase_wait_time)
color_chase(RED, color_chase_wait_time)
#will beep for the numer of seconds in time.sleep()
audio.play(sine_wave_sample, loop=True)
time.sleep(2)
audio.stop()
#red time's up before next start
pixels.fill(RED)
pixels.show()
time.sleep(3)
else:
pixels.fill(BLACK)
pixels.show()
led.value = False
time.sleep(0.01)
