I'm looking for a pin out diagram for the
NTSC/PAL (Television) TFT Display - 1.5" Diagonal
Product ID: 910
As I don't want to mix my ground and signal wires.
The wiring diagram I have has the wire colors/positions mixed and I just want to make sure I don't burn a board.
On an RCA jack the ground is the exterior ring correct? And the signal is inside the hole?
A pin out would be tremendous
Need help identifing pin out
- mikeysklar
Re: Need help identifing pin out
Probably best to use a multimeter to confirm the continuity on the center connector versus outer. There is a super detailed TFT connector description, but it does not have any diagrams or breakout RCA.
https://cdn-shop.adafruit.com/datasheet ... 000601.pdf
The bottom side of the PCB does have labeled RCA connection pins, but I can't quite make them out from the photo.
